Floorboard heat does not work. - JeepForum.com
post #1 of 23 Old 01-18-2014, 11:32 AM Thread Starter
donniesoup
1980 FSJ Cherokee
The heater will not blow out of the floorboards. Instead it blows out of the defrost. When on defrost it blows out of defrost. Has anyone had this problem? Is this a vacuum issue? Can anyone tell me how to fix this? Thank you.
2011 liberty 70th anniversary
1980 cherokee
Do what you should now so you can do what you want too later!
donniesoup is offline
post #2 of 23 Old 01-18-2014, 11:46 AM
Bmxer524
2011 KK Liberty
Mine does it. They told me it's "normal"....hate dealers. If you set it between the floor and floor/top vents, it should work pretty normally...
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is online now
post #3 of 23 Old 01-18-2014, 03:13 PM Thread Starter
donniesoup
1980 FSJ Cherokee
I've tried that too. Doesn't work. I would take it to dealer but out of warranty. Have 84k on it.
1980 cherokee
post #4 of 23 Old 01-18-2014, 09:17 PM
Bmxer524
2011 KK Liberty
Wow really racking up the miles lol. If you find a fix or what's wrong let me know!
post #5 of 23 Old 01-20-2014, 11:44 AM
LibertyRS
2012 KK Liberty
Same issues on my 2012 with 37xxx, haven't had time to deal with it. Big boots and wool socks
2012 Jeep KK
Stormtrooped
ZZzz
LibertyRS is offline
post #6 of 23 Old 01-30-2014, 09:00 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Info from the 2011 KK FSM:
24 - Heating and Air Conditioning/Controls/ACTUATOR, Blend Door/Description
DESCRIPTION
The heating-A/C system uses a reversible, 12-volt direct current (DC) servo motor which mechanically positions the blend-air door. The blend door actuator (1) is located on the driver side of the HVAC housing.
The blend door actuator is interchangeable with the actuators for the mode-air doors and the recirculation-air door. Each actuator is contained within a black molded plastic housing with an integral wire connector receptacle (2) and integral mounting tabs (3) that allow the actuator to be secured to the HVAC housing. The blend door actuator output shaft (4) is connected to the linkage that drives the blend-air door. The blend door actuator does not require mechanical indexing to the blend-air door, as it is electronically calibrated by the A/C-heater control.
24 - Heating and Air Conditioning/Controls/ACTUATOR, Blend Door/Operation
OPERATION
The blend door actuator is connected to the A/C-heater control through the vehicle electrical system by a dedicated two-wire lead and connector of the HVAC wire harness. The blend door actuator can move the blend-air door in two directions. When the A/C-heater control pulls the voltage on one side of the motor connection high and the other connection low, the blend-air door will move in one direction. When the A/C-heater control reverses the polarity of the voltage to the motor, the blend-air door moves in the opposite direction. When the A/C-heater control makes the voltage to both connections high or both connections low, the blend-air door stops and will not move.
The A/C-heater control uses a pulse-count positioning system to monitor the operation and relative position of the blend door actuator and the blend-air door. The A/C-heater control learns the blend-air door stop positions during the actuator calibration procedure and will store a Diagnostic Trouble Code (DTC) for any problems it detects in the blend door actuator circuits (Refer to 28 - DTC-Based Diagnostics/HVAC - Diagnosis and Testing) .
The blend door actuator cannot be adjusted or repaired and must be replaced if inoperative or damaged.
24 - Heating and Air Conditioning/Controls/ACTUATOR, Mode Door/Description
DESCRIPTION
The heating-A/C system uses a reversible, 12-volt direct current (DC) servo motor which mechanically positions the mode-air door. The mode door actuator (1) is located on the driver side of the HVAC housing.
The mode door actuator is interchangeable with the actuators for the blend-air door and the recirculation-air door. Each actuator is contained within a black molded plastic housing with an integral wire connector receptacle (2) and integral mounting tabs (3) that allow the actuator to be secured to the HVAC housing. The mode door actuator output shaft (4) is connected to the linkage that drives the mode-air door. The mode door actuator does not require mechanical indexing to the mode-air doors, as it is electronically calibrated by the A/C-heater control.
24 - Heating and Air Conditioning/Controls/ACTUATOR, Mode Door/Operation
OPERATION
The mode door actuator is connected to the A/C-heater control through the vehicle electrical system by a dedicated two-wire lead and connector of the HVAC wire harness. The mode door actuator can move the floor, defrost/demist and the panel-air doors in two directions. When the A/C-heater control pulls the voltage on one side of the motor connection high and the other connection low, the mode-air doors will move in one direction. When the A/C-heater control reverses the polarity of the voltage to the motor, the mode-air doors moves in the opposite direction. When the A/C-heater control makes the voltage to both connections high or both connections low, the mode-air doors stop and will not move.
The A/C-heater control uses a pulse-count positioning system to monitor the operation and relative position of the mode door actuator and the mode-air doors. The A/C-heater control learns the mode-air doors stop position during the actuator calibration procedure and will store a diagnostic trouble code (DTC) for any problems it detects in the mode door actuator circuits (Refer to 28 - DTC-Based Diagnostics/HVAC - Diagnosis and Testing) .
The mode door actuator cannot be adjusted or repaired and must be replaced if inoperative or damaged.
24 - Heating and Air Conditioning/Operation (See attached picture)
OPERATION
Both the manual temperature control (MTC) and the automatic temperature controlled (ATC) heating-A/C systems are blend-air type systems. In a blend-air system, a blend-air door controls the amount of conditioned air that is allowed to flow through, or around the heater core. This design allows almost immediate control of output air temperature.
NOTE: Typical blend-air type HVAC system shown.
The heating-A/C system pulls outside (ambient) air through the fresh air intake (4) located at the cowl panel at the base of the windshield and into the air inlet housing above the heating, ventilation and air conditioning (HVAC) housing and passes through the A/C evaporator (7). Air flow is then directed either through or around the heater core (2). This is done by adjusting the position of the blend-air door (3) with the temperature control located on the A/C-heater control in the instrument panel. Air flow is then directed out the floor outlet (8), instrument panel outlet (10) or the defroster outlet (1) in various combinations by adjusting the position of the mode-air doors (9 and 11) using the mode control located on the A/C-heater control. The temperature and mode control uses electrical actuators to operate the air doors.
The velocity of the air flow out of the outlets can be adjusted with the blower speed control located on the A/C-heater control.
The fresh air intake can be shut off by pressing the Recirculation button on the A/C-heater control. This will operate the electrically actuated recirculation-air door (5), which closes off the fresh air intake. With the fresh air intake closed, the conditioned air within the vehicle is pulled back into the HVAC housing through the recirculation air intake (6).
The A/C compressor can be engaged by pressing the A/C (snowflake) button on the A/C-heater control when the mode control is set in any floor to instrument panel position. The A/C compressor will automatically engage when the mode control is set in any Mix to Defrost position. This is done to help reduce fogging of the front windows by removing humidity from the conditioned air prior to it coming into contact with the windows.
The defroster outlet receives airflow from the HVAC housing through the molded plastic defroster duct. The airflow from the defroster outlet is directed by fixed vanes in the defroster outlet grille and cannot be adjusted.
The side window demister outlets receive airflow from the HVAC housing through the defroster duct and molded plastic demister ducts which are integral to the instrument panel. The airflow from the side window demister outlets is directed by fixed vanes in the demister outlet grilles and cannot be adjusted. The demisters direct air from the HVAC housing through the outlets located on the top corners of the instrument panel. The demisters operate when the mode control is positioned in the floor-defrost and defrost-only settings. Some air may be noticeable from the demister outlets when the mode control is in the bi-level to floor positions.
The panel outlets receive airflow from the HVAC housing through the center panel duct and the two molded plastic panel ducts, which are integral to the instrument panel. The two end ducts direct airflow to the left and right instrument panel outlets, while the center panel duct directs airflow to the two center panel outlets. Each of these outlets can be individually adjusted to direct the flow of air.
The floor outlets receive airflow from the HVAC housing through the floor distribution ducts. The front floor outlets are integral to the molded plastic floor ducts, which are secured to the sides of the HVAC housing. The floor outlets cannot be adjusted.
NOTE: It is important to keep the air intake opening clear of debris. Leaf particles and other debris that is small enough to pass through the cowl opening screen can accumulate within the HVAC housing. The closed, warm, damp and dark environment created within the housing is ideal for the growth of certain molds, mildews and other fungi. Any accumulation of decaying plant matter provides an additional food source for fungal spores, which enter the housing with the fresh intake-air. Excess debris, as well as objectionable odors created by decaying plant matter and growing fungi can be discharged into the passenger compartment during heater-A/C operation if the air intake opening is not kept clear of debris.
This A/C system uses an A/C expansion valve to meter the flow of refrigerant to the A/C evaporator. The A/C evaporator cools and dehumidifies the incoming air prior to blending it with the heated air. To maintain minimum evaporator temperatures and prevent evaporator freezing, an evaporator temperature sensor is used. The sensor is located downstream of the evaporator and supplies an evaporator temperature signal to the A/C-heater control.
JeepCares is online now
post #7 of 23 Old 02-05-2014, 06:53 PM
NAMoulton
2010 KK Liberty
I have this issue sometimes too. I go from defrost to feet all the time and I have to turn the fans off, then change the flow direction, then turn it back on in order for it to change flow directions. I think it's because the motor mechanism thingy is too weak for the air flow.
NAMoulton is offline
post #8 of 23 Old 11-18-2014, 01:15 PM
captpetey
2009 KK Liberty
driver's side blend door
Does anyone know how to move/replace the driver's side blend door? The diagram that JeepCares posted is great, but i'm not sure where to go from there. I have hot air on all passenger side vents, but only cold air on my side. All the directional/mode doors are working properly, but the temp is split domn the middle. my wife doesn't care, she's warm, but my side is freezing!
captpetey is offline
post #9 of 23 Old 11-19-2014, 08:41 AM
lfhoward
2008 KK Liberty
I just found this thread over on LOST about HVAC issues like you are describing. It has some solutions. http://www.lostjeeps.com/forum/phpBB...p?f=88&t=76917
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #10 of 23 Old 11-27-2014, 07:26 PM
s2killa
2011 KK Liberty
glad I read this that I was the only one going crazy
Instagram-DHR_S2KILLAA
11 Liberty KK l Daystar 2" l Rock Crawler 15x8 3.75" l M/T Baja MTZ 31x10.50
s2killa is offline
post #11 of 23 Old 12-02-2014, 10:36 AM
captpetey
2009 KK Liberty
So, after reading the links here and on the Nitro Forum, I cleaned/flushed the heater core... and I am willing to claim at least a temporary VICTORY. The driver's side still is not as hot as the passengers, but I don't think it ever was or ever will be. It is plenty warm for me, and more importantly the defroster works so I can see out the front at 6am to get to work. I have read that the issue often does return, but it only takes about 1/2 hour to clean out, so that's a lot better than taking the whole dash apart!
post #12 of 23 Old 01-14-2015, 08:01 AM
Peteroo
Just heard from my dealership that this is my problem...also not covered on my extended warranty..fml. time to crawl under and see what i can do
Peteroo is offline
post #13 of 23 Old 01-14-2015, 02:06 PM
rescue575
2011 KK Liberty
What warranty did you get?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #14 of 23 Old 01-15-2015, 10:03 AM
Peteroo
It was a crappy "added care plus" that was put on when i complained about a vibration. Looking into new vehicle and diy fix for this
Peteroo is offline
post #15 of 23 Old 02-15-2015, 06:30 AM
Tiga
2011 KK Liberty
Has anyone had their blend door actuator replaced by the dealer to fix this issue? I have the same problem - the heat works fine but I can not get it to direct to the floor. It's either window defrost or cabin vents. My understanding is their is a calibration process that needs to be followed once the actuator is replaced. If anyone had this done did it fix your issue and what did the dealer charge you? Thanks!!
Tiga
Tiga is offline
