Feeler: New kk front recovery system - JeepForum.com
post #1 of 51 Old 02-06-2013, 11:09 PM Thread Starter
AtTheHelm
I want to see if there would be any interest from anyone on here for a new front recovery system i've been thinking about. It would be perfect for someone who wants a front hitch for a winch plus shackles instead of the factory tow hooks. As some of you know, the kk's tow hooks come with a flimsy 'm' bolt that has been known to tear out of the unibody frame rails. This would mount to the same location but have a nut rail that will spread the load a lot more from the extra surface area, thus making it much stronger. It would be made of square structural steel and 1/4" angle on the mounts.
My reasoning behind this is to give people who wheel their kks something better than the oem tow hooks but also not making the jump to a full steel winch bumper.
Let me know your feedback: good/bad/suggestions.
I won't even begin to prototype this for a while though because i have bumper orders that need to be finished first.
AtTheHelm is offline
post #2 of 51 Old 02-07-2013, 05:17 AM
eoerikson3
2011 KK Liberty
If I read this correctly this would be a winch mount plus shackle mount? I'd be interested. Right now I am considering your bumper or the backbone system from Detours for mounting a winch.
Re-read it. I think someone makes the front receiver already. I am not terribly interested in that.
-Oscar
Chrome may not get you home, but sometimes it looks nice.
2011 Liberty Sport
Added tow hitch, tow hooks, skid plates, foglight kit and headlight masks, remote start, chrome steps, and Cooper Discoverer A/T3 235/75R16.
eoerikson3 is offline
post #3 of 51 Old 02-07-2013, 06:43 AM
jonrjen
2011 KK Liberty
I am sure there is a need/want/desire for such an item out there, but I also feel sure that it may be a very limited market to sell to. Throw in that you can by a front receiver that include two chain loops for $185 it might be difficult to compete in the price arena.
That being said, if you were to make it with the front receiver hitch, then build the shackle tow mounts in a fashion that they would also be able to double as tow bar mounts and two loops for safety chains while being towed you could have a winner. This would cover the needs of a wider market base.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #4 of 51 Old 02-07-2013, 08:49 AM Thread Starter
AtTheHelm
Yes, you guys are right, curt makes a front hitch for the kk already. The problem with theirs is the receiver sits BELOW the front fascia (plastic factory bumper). Also those chain loops should not be used as tow hooks for recovery, ever. The receiver on mine would sit in the opening between the factory tow hooks and you get real shackle mounts. That entire plastic vent would need to be cut out. I won't know if there are cooling or clearance issues until i build one and run/test it for a while.
This is taken from etrailer's website regarding the curt front hitch on the liberty.
What is the Ground Clearance with a CURT Front Trailer Hitch Installed on a 2007 Jeep Liberty?
According to the installation instructions which I have linked for you, the CURT Front Mount Receiver, # C31022, receiver opening will be directly below the front fascia. If you measure from the ground to the bottom of the fascia on your 2007 Jeep Liberty, and then subtract 2-1/2 inches, this is approximately where the bottom of the receiver should be. Make sure you are on level ground when measuring.
view full answer...
post #5 of 51 Old 02-07-2013, 09:49 AM
jonrjen
2011 KK Liberty
You are indeed correct, I looked at the Curt system when I purchased my KK. I thought that maybe I could bolt on a pair of tow bar brackets to the square tube, but with it sitting so low that was not an option. And the ground clearance would greatly suffer.
I ended up going ahead and ordering the Blue OX tow bar mount for the KK which exits through the lower opening of the front bumper screened area. I have had no issues with overheating due to this addition. If you go to either the ETrailer or BlueOX website they show the installation instructions via a download which may give you a heads up as to how these are mounted.
jonrjen is offline
post #6 of 51 Old 02-07-2013, 12:41 PM Thread Starter
AtTheHelm
Still this something that is tailored for kk owners that want strong recovery points plus a place to mount a winch when its needed without much added weight and a lot of $$. I won't know a price until i build one but it will be less than the blue ox towbar mount but probably more than the curt front receiver.
It looks like 3"x3"x1/4" tube will work best, that would allow a receiver tube and the shackle mounts to pass through the tube and be welded front and back the way they should be for strength.
post #7 of 51 Old 02-07-2013, 01:03 PM
huntb
2008 KK Liberty
It really doesn't look like that blue ox could be used for recovery either. It looks like strictly towing.
huntb is offline
post #8 of 51 Old 02-07-2013, 07:46 PM
_benjammin
2012 KK Liberty
I'd be interested. And am wondering if a piece of c channel could be added in front of the entire bumper?
_benjammin is offline
post #9 of 51 Old 02-07-2013, 08:07 PM
KK4x4
2009 KK Liberty
What if you took that and made sort of like a bull bar outta it that had bars sort of like across the bumper width them came up like the matrix or Aries for lights and a little protection as well. Just trying to help out a bit with ideas...
KK4x4 is offline
post #10 of 51 Old 02-07-2013, 09:59 PM Thread Starter
AtTheHelm
Thanks for the feedback guys. I was really trying to keep it simple and low profile. I never liked adding things outside of the plastic bumper like a bullbar because of the loss of approach angle and the way it looks. I can see maybe a simple prerunner style hoop for lights maybe but it would still stick out and wouldn't offer serious protection like a steel bumper would. Adding on stuff like that adds production cost as well as shipping cost too. I'm trying to keep it affordable.
Maybe something like the jk hood light bar but better and made to be bolted to the top of the plastic bumper?
post #11 of 51 Old 02-08-2013, 07:26 AM
_benjammin
2012 KK Liberty
I was thinking I may be able to weld up something to your recovery system. Wasn't necessarily thinking of you incorporating it into your design, mainly because of the additional cost on your end, including shipping. Thinking something like the 4X for a KJ from JBA without the hoop.
If it was high enough I was hoping to not interfere with approach angle but provided a little protection to the plastic bumper. I'm not comfortable/confident with my welding for structural support and potential recovery.
post #12 of 51 Old 02-11-2013, 10:31 PM Thread Starter
AtTheHelm
Quicky wooden mock up i made at work. Its going to have to be 3"x3"x1/4" square structural tube, 3/4" thick shackle mounts, standard 2" id receiver, 1/4" gusseted mounts, and most likely 8 bolted points which are the tow hook holes and four in the crossmember with heavy backing plates. Weight around 35lbs. Don't comment on the paint color its for demonstration purposes. I'll get a pic of it in position on the Jeep soon.
[/quote]
post #13 of 51 Old 02-12-2013, 09:09 AM
jonrjen
2011 KK Liberty
Mock up looks rather good.
jonrjen is offline
post #14 of 51 Old 02-12-2013, 01:01 PM
mtbiker
2011 KK Liberty
I'd be interested
mtbiker is offline
post #15 of 51 Old 02-12-2013, 02:46 PM
otlip
Interested
I'm in
otlip is offline
