Esp & 4wd - JeepForum.com
post #1 of 10 Old 01-13-2011, 08:11 PM Thread Starter
08KKJeepGrn
2015 JK Wrangler
Esp & 4wd
please help..
1) can you fully disable the ESP function?
I switch the Jeep into 4WD and turn OFF the ESP and the Jeep acts the way a 4x4 should act in deep snow (all wheels in motion) but i'm still getting a little bit of grinding.
2) When I switch the ESP OFF and then when needed I select 4WD the ESP automaticly switches back ON
3) What is the purpose of the ESP function of the ESP when 4WD is enabled
It's not like the older durango's where you select 2WD to 4WD and when you in 2WD your back wheels just spin... When i'm in the Jeep in 2WD and hit a slippery spot the ESP just grinds...... it this normal??
i'm boggled!!
08 Liberty Limited Jeep® Green
'15 Jeep Wrangler Unlimited Silver
08KKJeepGrn is offline
post #2 of 10 Old 01-13-2011, 08:46 PM
leakslikasieve
The answer to your questions has been reviewed multiple times. However, its very easy to explain.
The ESP has stability and traction control. In 4wd high with the esp button turned off, it will turn only esp off, TC stays on, but allows for more slip. The only way it will turn off fully is by switching into 4wd low or pulling the abs fuse.
And by the way, I HATE this. I feel that it defeats the purpose of 4wd. Sometimes you need to just spin a bit.
previous- 98 xj classic
current- 2006 mazdaspeed 6, 2010 liberty sport
leakslikasieve is offline
post #3 of 10 Old 01-13-2011, 08:52 PM
otlip
ESP Modes: Activation
Normal Vehicles SRT Vehicles
Select
4x4 Vehicles
Fully ON
Defaults to Fully ON when starting vehicle, or when shifting
the transfer case on 4x4 vehicles
Partially OFF Press at any speed. [ESP OFF]
Fully OFF Not
Applicable
Press and hold 5-14 sec.
while under 10 mph [ESP OFF]
Fully ON
Fully ON is automatically engaged, requiring no specific driver input. The system defaults to Fully ON
each time the key is turned from the “off” to the “on” position or when shifting the transfer case on 4x4
vehicles. One push of the ESP button will put ESP back into the Fully ON mode if the vehicle is already
in the Partially OFF or Fully OFF setting.
ESP Switch
ESP Warning Light
Partially OFF
To select the Partially OFF mode, a single press of the “ESP OFF” button
at any speed is all it takes. A warning lamp in the instrument cluster will
illuminate.
Fully OFF
To select the Fully OFF mode, press and hold the “ESP OFF” button for
at least 5 seconds but not more than 14 seconds while under 10 mph. A
chime will sound, a warning lamp will illuminate and a text message —
ESP OFF — will appear in the instrument cluster (on vehicles with EVIC).
When 4x4 vehicles exceed 40 miles per hour, ESP automatically
switches from Fully OFF to Partially-OFF. In 4x4 vehicles, added safety
is achieved by having all of ESP’s features active above 40 mph. This is
not done in SRT vehicles because these vehicles are optimized for
higher rates of speeds.
http://www.socallx.com/esp_modes.pdf
otlip is offline
post #4 of 10 Old 01-14-2011, 11:27 AM
redmario
2010 KK Liberty
Follow this procedure to permanentely disable ESP (full off). Do it again to turn ESP back on.
It will flash e"sp off" if you do it correctly and display the wavy lines all the time..
1. Place into 4H
2. turn jeep off then on (actually start the jeep)
3. center wheel
4. turn clockwise so JEEP is upside down at 180 degrees
5. press and hold esp for 7 seconds (at 5 secs you will hear one chime) now depress the esp button keeping the wheel in the same position hold 7 seconds. you will hear another chime.
6. recenter wheel
7. turn counter clockwise till JEEP is upside down.
8. Press and hold ESP for 7 seconds (at 5 secs you will hear one chime) now depress the esp button keeping the wheel in the same position hold 7 seconds. you will hear another chime.
9. Recenter wheel
10. Press and hold ESP for 7 seconds. then depress until you hear the chime.
11. Turn off Jeep
redmario is offline
post #5 of 10 Old 01-14-2011, 06:51 PM Thread Starter
08KKJeepGrn
2015 JK Wrangler
Cool! ..Redmario, Will the 4WD system act normal and will the ESP Car image on the cluster be off or will it stay on?
post #6 of 10 Old 01-14-2011, 08:10 PM
r1967a
1. Place into 4H
3. center wheel
6. recenter wheel
9. Recenter wheel
11. Turn off Jeep
Actually when I do the above sequence the car image flashes 6 times, each a different color red, green, blue, yellow, orange, and brown...hope that helps 08kk!!!
r1967a is offline
post #7 of 10 Old 01-15-2011, 08:33 AM Thread Starter
08KKJeepGrn
2015 JK Wrangler
Ok... I think after ready both scenarios I'm going to try. Also do I have to repeat everytime want the ESP FULL OFF or will it stay off when done once? When I shut the Jeep off will it reset it self back to normal operation?
post #8 of 10 Old 01-16-2011, 02:19 AM
r1967a
it should work the first time and keep it off, if it does NOT work....after step 11, you may have to do the whole process again, but at step 11 push and hold the esp button for 25 seconds, or until it "dings" and within 5 seconds of it "dinging" lock and unlock the jeep via the remote (yes while your sitting in the jeep still) 3 times, after this you should get a confirmation ding sound of 3 "dings" once you have done this it should stay off until you reactivate it. Good luck and let us know how it turns out!!!!
r1967a is offline
post #9 of 10 Old 01-16-2011, 07:20 AM Thread Starter
08KKJeepGrn
2015 JK Wrangler
Ok. Last question, how can I turn the ESP back to normal when its not snowing and I have dry payment?
post #10 of 10 Old 01-17-2011, 02:49 AM
r1967a
from what i understand even though the "special instructions" to turn it completely off you should just be able to push the esp button and it turns it back on. If not you should be able to disconnect the battery, for about 5 minutes or so, reconnect it, turn the key to the "on" position, dont crank the motor, and within 5 seconds pump the gas peddle 5 times, then start the jeep. That should for sure turn it back "on" to normal!! Good luck!!!!
r1967a is offline
