ESC off then SERV 4WD, 4 LOW and 4WD lights on whiles driving - Page 2 - JeepForum.com
 2Likes
post #16 of 63 Old 07-11-2013, 12:21 PM
RKK
2012 KK Liberty
Where is the speed sensor located ? Do remember the sensors that you cleaned ?
RKK is offline
post #17 of 63 Old 07-11-2013, 07:17 PM
redncfootball
2010 KK Liberty
Drivers side rear. Behind rotar, there is a wiring harness only one you cant miss it
redncfootball is offline
post #18 of 63 Old 08-07-2013, 06:38 PM
jc_cshmny
2011 KK Liberty
Finally made it into the dealer and got the following codes:
FDCM C1403 - Transfer Case Range Position Sensor Performance (stored)
FDCM C1404 - Transfer Case Range Position Circuit Low (active)
Any help is appreciated! Still having the same issues as posted earlier in the thread.
jc_cshmny is offline
post #19 of 63 Old 08-08-2013, 08:17 AM
Slayers
2008 KK Liberty
When they gave you the codes they should have talked to you about replaceing the module in the TC or the PCM.
Slayers is offline
post #20 of 63 Old 08-08-2013, 09:08 AM
jc_cshmny
2011 KK Liberty
Originally Posted by Slayers View Post
When they gave you the codes they should have talked to you about replacing the module in the TC or the PCM.
He mentioned that it could be anything from a short, to failed sensors, to a bad FDCM. My issue is with them charging $100/hour to hunt for the problem, then paying them to fix it, especially since it is only 9k out of the bumper to bumper. This should really be covered under powertrain since it prevents me from using 4WD.
post #21 of 63 Old 08-08-2013, 09:39 AM
Ted15
2010 KK Liberty
If you bought it new or if it's under 100,000 miles then it should be covered, I think. Ask Jeep Cares
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #22 of 63 Old 08-08-2013, 10:13 AM
jc_cshmny
2011 KK Liberty
I've been told that if it's not an "internally lubricated part," it's not covered.
post #23 of 63 Old 08-08-2013, 02:11 PM
Edwardkain
2008 KK Liberty
It is the car alignment dude. If you are driving and it happen that means that you become beyond the proper car alignment and by this it means that one of your front or back suspension components is damaged "end tie rod, ball joints in the upper contol arm or the lower one and the bushing for both, sway bar bushing..etc." for these parts or the other parts that is related to your frontal suspension if any of them is damaged the esp and the 4wd and the abs will stop working because the will accure an unwanted car stabilizating. Check them because they are the one's that cause the sudden change in your car alignment and the stop of the esp function and the rest that is related to it.
Edwardkain is offline
post #24 of 63 Old 11-29-2013, 07:43 AM
welder74
2014 JK Wrangler
Getting tired of this....
I have been dealing with this same issue on my '11 Liberty(25k) for a month now. First time dealer had to reprogram the computer and now 3 weeks later every light regarding ABS, parking brake, seatbelt, serve 4wd, hill descent are on and after shutting down you must wait a few minutes to restart. I am not happy as this is my second Liberty after trading in my '09 w/sky slider roof issues. Has anyone continued to have problems after being "repaired"?
welder74 is offline
post #25 of 63 Old 01-16-2014, 06:37 PM
sourjeep
I have an 2010 bought new in Feb 2011 ,Jeep Liberty. I have had The lights ESPOFF, SERV4WD, 4 LOW, and 4WD lights come on for the forth time now. The first time was within 2months after buying it and I took it back to the dealership and they unhooked the battery left it overnight and connected it back up and they were off...that lasted until about june of 2011 and it happened again. I had moved to Colorado and took it into the local jeep dealership which found an C1404 error and replaced the Transfer case motor..still under warranty. Everything was good until Dec of 2012 and it happened again. Went back to the dealership and they once again found an C1404 error and replaced the Transfer case motor and was told would be covered under the pwer train warranty. Well guess what, its 2014 and its back. I called (877)426-5337Jeep Company Customer Service and explained my issue. What I was told was that I would have to have diagnostics run at a dealership to determine what the problem was. . And depending on what it was they would then assign a case worker to my issue and see what they could do for me as far as paying for the problem.
I called the Jeep Dealership in colorado since I am no longer there and asked for copies of my work and then called Jeep Company Customer Service back and asked if my Jeep was still under power train warranty. They confirmed it was so I am hopeful that when I go to have it diagnosed, I am in So California now, that it will be covered under warranty, if not I have a case number with Jeep and will continue to fight for 100% cost coverage. Its obivious that this is a known issue. It has really disheartened me towards owning a jeep in the future. Good Luck everyone!
sourjeep is offline
post #26 of 63 Old 02-19-2015, 12:48 AM
evilxangel315
this came on when I ended up getting stuck in a snowbank today. my brakes are pretty jumpy now and I cant engage or dis engage 4wd. all its saying is ESCOFF. After reading this im lucky that it doesn't say service 4wd or else I would die. what do I do to get this fixed? or do I have to take it in to fix it?
evilxangel315 is offline
post #27 of 63 Old 02-19-2015, 01:50 AM
josworth
2010 KK Liberty
This thread is muddled with a few different issues. Considering you were stuck in snow, I would check for packed snow in the brake area. More than likely a speed sensor is clogged up. If a speed sensor at one of the wheels isn't able to signal the system it disables 4wd as well. Hopefully it's just that simple.
Jeff
2010 Honda Crosstour AWD-V6
josworth is offline
post #28 of 63 Old 02-19-2015, 05:18 AM
yzf125
2012 KK Liberty
Man, reading some of these threads in this forum just make me regret buying my Liberty LOL I sure hope these problems like this aren't the norm for Lib owners...
yzf125 is offline
post #29 of 63 Old 02-19-2015, 05:32 AM
josworth
2010 KK Liberty
Yup YZF125... was up early this morning, answered that post and got ready for work. Right after getting on the highway in ice and snow, my dash lights lit up and now my stuff is shut off as well. I have really just about had enough of this POS. I have tried so hard to remain positive. I so loved my Cherokee's back in the day. I even forgive stuff knowing it is built to a price point. It seems lately that every other week it's something.
Jeff
josworth is offline
post #30 of 63 Old 02-19-2015, 06:26 AM
yzf125
2012 KK Liberty
I bought mine to AVOID having trouble like this !! I upgraded from a 03 Chevy Silverado that was nickle and diming me to this ??? Its not a comfortable feeling knowing all that can and will in most cases happen eventually.. I may seriously just try to sell mine in the spring to avoid going through any of this nonsense... Wish I would have read this forum head to toe before buying mine.......
yzf125 is offline
Driving lights cnypt KK Liberty Forum 3 12-23-2015 10:28 PM
Play DVD While Driving 1stJeepKK KK Liberty Forum 19 05-26-2015 02:08 PM
Driving on Sand otlip KK Liberty Forum 3 07-26-2011 02:11 AM
Driving in Snow 09kk KK Liberty Forum 16 05-19-2010 04:03 PM
LED lights for reverse lights Wnahikian KK Liberty Forum 0 02-17-2010 08:48 AM
