Easy Entry/Exit Seat - JeepForum.com
post #1 of 10 Old 10-02-2012, 11:27 PM Thread Starter
robert531
2011 KK Liberty
The easy entry/exit feature has stopped working on my 2011 Liberty. This happened once before and the tech said I had it turned off. I don't know how as I never touched the system. This time I checked the EVIC menu and it said the feature is "on". I tried turning it off and on with no luck. Has anyone else had this problem and/or know how to solve it? Thanks, Robert
robert531 is offline
post #2 of 10 Old 10-05-2012, 08:58 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Here is some information on how it is supposed to work:
Info from the 2011 Liberty Owner Manual:
Memory Position Recall
NOTE:
• For vehicles equipped with an automatic transmission, the vehicle must be in PARK to recall memory positions. If a recall is attempted when the vehicle is not in PARK, a message will display in the EVIC, if equipped.
• For vehicles equipped with a manual transmission, the vehicle speed must be at 0 mph (0 km/h) to recall memory positions. If a recall is attempted with the vehicle speed above 0 mph (0 km/h), a message will display in the EVIC, if equipped.
To recall the memory settings for driver one, press MEMORY button number 1 or the UNLOCK button on the RKE transmitter linked to memory position 1. To recall the memory setting for driver two, press MEMORY button number 2 or the UNLOCK button on the RKE transmitter linked to memory position 2. A recall can be cancelled by pressing any of the MEMORY buttons (S, 1, or 2) during a recall. When a recall is cancelled, the driver seat will stop moving. A delay of one second will occur before another recall can be selected.
(Available With Memory Seat Only)
This feature provides automatic driver seat positioning to enhance driver mobility when entering and exiting the vehicle. The distance the driver seat moves depends on where you have the driver seat positioned when you remove the key from the ignition switch.
• When you remove the key from the ignition switch, the driver seat will move about 2.4 in (60 mm) rearward if the driver’s seat position is greater than or equal to 2.7 in (68 mm) forward of the rear stop. The seat will return to its previously set position when you insert the key into the ignition switch and turn it out of the LOCK position.
• When you remove the key from the ignition switch, the driver seat will move to a position 0.3 in (8 mm) forward of the rear stop if the driver’s seat position is between 0.9 in and 2.7 in (23 mm and 68 mm) forward of the rear stop. The seat will return to its previously set position when you insert the key into the ignition switch and turn it out of the LOCK position.
• The Easy Entry/Easy Exit feature is disabled when the driver’s seat position is less than 0.9 in (23 mm) forward of the rear stop. At this position, there is no benefit to the driver by moving the seat for Easy Exit or Easy Entry.
Each stored memory setting will have an associated Easy Entry and Easy Exit position.
NOTE: The Easy Entry/Easy Exit feature can be turned on or off through the programmable features in the EVIC.
Automatically Move Seat Back on Exit — If Equipped
This feature provides automatic driver seat positioning to enhance driver mobility when entering and exiting the vehicle. To make your selection, press and release the FUNCTION SELECT button until “On” or “Off” appears.
NOTE: The seat will return to the memorized seat location (if Recall Memory with Remote Key Unlock is set to ON) when the RKE transmitter is used to unlock the door. Refer to “Driver Memory Seat” in “Understanding The Features Of Your Vehicle” for further information.
Info from the 2011 Liberty Service Manual:
MEMORY SEAT SYSTEM
An electronic memory seat system is available on certain models. The memory system is able to store and recall all driver side power seat positions and driver outside mirror position. The system can be set for two different drivers. On vehicles with a factory installed radio connected to the Controller Area Network (CAN) data bus network, the memory system is also able to store and recall up to twelve radio station presets (six AM and six FM), for two drivers. The memory system will also store and recall the last station listened to for each driver, even if it is not one of the twelve preset stations.
The memory system will automatically recall all of these settings when a button of the memory switch is depressed, or when the doors are unlocked using the Remote Keyless Entry (RKE) transmitter (if enabled). If the vehicle has more than two drivers the RKE transmitter recall of memory features can be disabled. This is a customer programmable feature of the Electronic Vehicle Information Center (EVIC) set through the use of the appropriate steering wheel switches (Refer to 08 - Electrical/8M - Message Systems/Message Center/CENTER, Electronic Vehicle Information - Operation) .
The memory system also has an “Easy Entry and /Exit” feature that provides the driver with more room to enter or exit the vehicle. When the seat is in a memorized position, it will move rearward 60 millimeters or to the end of its travel, whichever occurs first, when the key is removed from the ignition switch lock cylinder. This is also a customer programmable feature of the Electronic Vehicle Information Center (EVIC) set through the use of the appropriate steering wheel switches.
JeepCares is online now
post #3 of 10 Old 10-06-2012, 04:22 AM
fairmont1998
2012 KK Liberty
Try moving the seat, then recalling your settings with the memory button. Then remove the key and see if the seat moves back.
2012 KK Cherokee Limited CRD
fairmont1998 is offline
post #4 of 10 Old 10-07-2012, 11:14 AM Thread Starter
robert531
2011 KK Liberty
Hi Lee,
Thanks for the info. I wish I could say it was working. Unfortunately, NOT. I've tried everything including the recommendation of another respondee. I need to take it in. My problem is time. Thanks again, Robert
NOTE:
MEMORY SEAT SYSTEM
post #5 of 10 Old 10-07-2012, 11:18 AM Thread Starter
robert531
2011 KK Liberty
No joy! Thanks for the recommendation. I did as you suggested, but when I removed the key - nothing. I'll keep trying. Robert
post #6 of 10 Old 10-08-2012, 09:23 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Originally Posted by robert531 View Post
Hi Lee,
I know - I have the same problem.
post #7 of 10 Old 10-15-2012, 03:35 PM Thread Starter
robert531
2011 KK Liberty
I found a solution on the Jeep Garage Forum. I had apparently moved the seat all the way to the rear when I was cleaning it. For some odd reason this stops the Easy Entry/Exit system from working. To fix it, you first turn the Easy Entry/Exit system off. You then move the seat all the way forward, then all the way back. You then press your number button to move to your normal position. Re-enter Personal Settings and turn Easy Entry/Exit back on. Remove your key and it should work. A very easy fix that should really be in the manual.
post #8 of 10 Old 10-16-2012, 05:25 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Great! Thanks for coming back and posting what worked.
post #9 of 10 Old 04-06-2014, 07:56 PM
llm317
2014 JK Wrangler
Thank you for saving my sanity. This just stopped working in my '11 Liberty this morning. Your instructions fixed it!
llm317 is offline
post #10 of 10 Old 09-30-2014, 03:45 AM
daforges
Hi There, I have a problem with the memory seats in my Jeep Grand Cherokee 2004. the problem is, is that when I get out of the car for any length of time, the seat changes position all by itself so that when I get back into the car I have to re-position the seat again. this happens every time now.
I have tried disconnecting the battery and shorting out the leads for half an hour to reset the cars memory, this didn't work. I've even disconnected the memory seat switch in the door card, all that did was made me think that some invisible driver is in my car because even with that disconnected, the seat still moves by itself. in the overhead display (when the switch was connected) the readout was "memory seat disconnected" "vehicle not in park". that's why I disconnected the switch to hopefully make the problem go away but as the seat still moves all by itself, the problem still persists.
Does anyone have any solutions as to what the heck is wrong with my car? or am I doing something wrong? please help....
daforges is offline
Third Row Seat floodlit KK Liberty Forum 6 08-10-2011 05:00 PM
Seat covers DaveV KK Liberty Forum 1 03-01-2011 04:47 PM
Easy/Cheap/Fun/Better Productivity Mods to add? slipperybrain KK Liberty Forum 0 02-07-2011 07:19 PM
Keyless Entry Issue! itsgrooveybaby KK Liberty Forum 1 02-02-2011 11:20 AM
easy exit feature reset? jeepster09 KK Liberty Forum 0 05-01-2010 06:03 AM
