Duratrac's on the KK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Duratrac's on the KK
JK Vent Covers - NalinMFGRCV Axles at CCORPoison spyder items @ oconee off road 706 534 9955
Unread 08-20-2014, 08:50 PM   #1
goser
Hey Folks, just purchased a KK... picking it up tomorrow... and I noticed that Canadian Tire is having a sale on Duratracs next week. I had these tires on my Patriot and loved them, and I've never seen them on sale before, so I figure I should pick up a set while I can.
My liberty has 17's on it, but I'd probably be looking to pick up a set of stock sport 16" wheels... I just like the look of them better.
The Liberty isn't lifted... I intend to lift it someday, but is probably not in the cards for the foreseeable future.
What would be the largest Duratrac I can fit on a stock 2010 Liberty with 16's?
I know, according to the wikibooks page, that 225/75-R16 would fit, but that was the size I had on the Patriot and I would die a little inside if that was the largest I could put on the Liberty.
I saw a thread yesterday while I was doing some research that 215/85R16 worked for somebody but I can't find that thread again. What are people's thoughts on a 215 tire?
I also saw someone say that 245/75R16 worked for him with no lift, but the wiki page says that would have some rub even with a lift...
Is there a better resource out there I'm missing? What are the limiting factors/common rub points for a non-lifted KK?
Thanks!
goser is offline   Reply With Quote
Unread 08-20-2014, 10:18 PM   #2
lfhoward
2008 KK Liberty
I have 245/75/R16 Duratracs and a 4 inch lift. With my lift I could be running 265/75/R16's but I would need to regear to maintain good performance. Many people run 245/75/R16 Duratracs with 2.5 inch OME lifts, and some with Daystar spacer lifts (though that lift is not as good as a full spring lift). Occasionally someone will post that they can run 245/75/R16s with no lift if they pound their pinch welds, but it seems short sighted to me. As their springs age and sag, they will eventually rub on turns and bumps. 225/75/R16 Duratracs do work on stock KK's.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline   Reply With Quote
Unread 08-21-2014, 04:17 AM   #3
NAMoulton
2010 KK Liberty
I've heard people doing 235/70 16s stock and fits perfect, but then I don't think duratracs are made for that size. EDIT: They don't haha.
As for the rims, I have all four of my old '10 stock rims still. PM me if you're interested in them.
I think only Drednot has the 215s. They look nice though, and I'm a fatter tire kind of guy haha.
Custom Bumper-JBA/Daystar Lift-16x8 M13 Rims-265/70 General Grabber AT2s-K&N CAI-Airaid TBS
NAMoulton is offline   Reply With Quote
Unread 08-21-2014, 05:37 AM   #4
98ZJ SFD
2012 KK Liberty
235/70/16 was an optional OEM size. That's what came stock on mine. But I ended up putting on 225/75 DuraTracs on mine.
Current
2012 KK Sport, Mopar skids, DuraTracs, Mopar Grille Guard
Previous
98 ZJ Laredo SE 4.0, 2" Skyjacker BB, JKS Quicker Discos, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, Westin Safari bar, KC lights
98ZJ SFD is offline   Reply With Quote
Unread 08-21-2014, 07:34 AM   #5
Gageraid
2008 KK Liberty
225/75/16 Duractrac is all that I would do if I were you.
I'm running that size, but BFG A/T and they look great.
I've read that common rubbing points are on the pinch welds and front sway bar.
You could do a bigger tire if you feel like messing around with the pinch welds. I've even seen some people trim the front bumper, but not sure if it was for looks or to fit a bigger tire.
You're right on track with wanting a 16 inch wheel.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline   Reply With Quote
Unread 08-21-2014, 08:48 AM   #6
tommudd
2004 KJ Liberty
215-85-16 is way too skinny of a tire, plus shouldn't run it on anything wider than a 6 inch wide wheel
Run 245-70-16 or 225-75-16
Duratracs are really good all around tires for sure
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote
Unread 08-21-2014, 09:35 AM   #7
Bmxer524
2011 KK Liberty
I run 245/75-16 Duratracs on 3.5" of lift(looking to go to 265/75-16 eventually...). Like said, you'll need about 2-2.5" to clear them with no problems. Some have done it with no lift, but had to trim and would rub when flexing.
225/75-16 is a stock tire, generally you can go to 245/70-16 when stock with little to no rubbing. Not sure if Duratracs come in that size. I never really looked.
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote
Unread 08-21-2014, 10:40 AM   #8
goser
Seems like 225/75-16 will be the way to go... and if the tires are still good when I get around to lifting it I can always donate them to the Patriot
Unread 08-25-2014, 03:21 PM   #9
JoeTDI
2012 KK Liberty
Ha... we are in a similar boat.... after the lift gets installed on my KK and I get 245/75/16 Duratracs on it, I'll be switching my 235/70/16 Cooper Discoverer AT3's over to the Patriot....
Current: 2012 KK-2012 MK Patriot
Past: 1965 CJ5-1985 XJ-1995 ZJ-1999 TJ-2002 KJ-2006 KJ
JoeTDI is offline   Reply With Quote
