Driving in Snow - JeepForum.com
post #1 of 17 Old 04-25-2010, 01:14 AM Thread Starter
09kk
2009 KK Liberty
Driving in Snow
Is there anyway to keep the jeep liberty from cutting off throttle and making a weird noise... "I've heard it's normal but I don't want anything to get damaged" when the tires slip in the snow? I'm not doing donuts or anything but I'd rather control the vehicle myself. Thanks.
09kk is offline
post #2 of 17 Old 04-25-2010, 10:55 AM
rugsucka
Read the manual in the glovebox and you can be enlightened and educated to the modern features of this wonderful 4x4, and press the ESP button on your dash.
rugsucka is offline
post #3 of 17 Old 04-25-2010, 07:12 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Thats the ESP applying your rear brakes and managing the Throttle. Perfectly Normal. You can press the ESP Button but it doesnt fully disable it, it simply up's the treshhold. But you should keep it on since this is designed to help your vehicle operate safer when traction is lost. Id hate to see someone turn off ESP and loose control when it might have been avoided with it on.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #4 of 17 Old 04-27-2010, 08:38 PM
GearGuy10
It would be nice to be able to turn it off when you want to. I'd like to have the choice. There are sometimes when I want to give it gas to blast through a snowbank or something and the ESP cuts me off. Not cool.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
post #5 of 17 Old 04-27-2010, 10:10 PM
tjkj2002
2002 KJ Liberty
Pull the ABS fuse,no more ESP or ABS to worry about.
tjkj2002 is offline
post #6 of 17 Old 05-12-2010, 01:53 PM
LibertyHopeful
2008 KK Liberty
Yeah, I was 4x4ing in mad snow last week. Was actually only about 10 inches deep, but there was ice underneath -- had no trouble in 18 inches of snow, but it was that darn ice. I forgot about turning ESP off and I had that pit in the stomach feeling because I thought I was going to get stuck and I was 40 miles from the nearest town (offroading in the backcountry of Canada -- yeah, not a good idea to go alone, I know. That's why I quit while I was ahead.). Soon as I realized I had ESP on, hit the button, spun the wheels like crazy and got out of there.
Wish ESP could be fully disabled though for fun times snow drifting. It just eats up your brakes. I've heard you can pull the fuse for the ESP in the glovebox and that will fully disable it though. To turn it back on, just plug the fuse back in.
2008 Jeep Liberty Limited 4x4
Inferno Red | Pastel Pebble Beige
uConnect GPS • Power Sunroof • Skid Plate Group • Trailer Tow Class III Group
Pirelli Scorpion ATR 235/65R17 • WeatherTech Floor Liners • Mopar Cargo Tray
LibertyHopeful is offline
post #7 of 17 Old 05-12-2010, 01:55 PM
LibertyHopeful
2008 KK Liberty
Ah, it's the ABS fuse? Not one separately just for ESP? How does one know which fuse controls the ABS? Would I be right to assume it's outlined in the manual?
post #8 of 17 Old 05-14-2010, 10:45 AM
Nitz240d
2010 KK Liberty
Yes, there is a fuse panel diagram with labels in the owners manual.
-Erik
Nitz240d is offline
post #9 of 17 Old 05-14-2010, 11:23 AM
Mr_Harry
2014 JK Wrangler
Or put in a togggle switch for donught mode
Mr_Harry is offline
post #10 of 17 Old 05-15-2010, 05:24 PM
LibertyHopeful
2008 KK Liberty
I like! How can that be done?
post #11 of 17 Old 05-15-2010, 05:41 PM Thread Starter
09kk
2009 KK Liberty
LOST JEEPS • View topic - ESP On/Off Switch install "For off road use."
09kk is offline
post #12 of 17 Old 05-19-2010, 06:31 AM
Nitz240d
2010 KK Liberty
Ok so now I have to ask since we're on the topic. I fully understand the concept of a locking differential and I know that driving in the '4 wheel lock' in dry conditions puts a lot of stress on the drivetrain, but, as someone who hasn't ever gone off-road before (well at least not in the way you guys do), I'm just curious as to what this means for driving in the snow?
What happens when you have to make a tight turn in the snow (like a 90 degree turn into a driveway or going into a parking spot)? Also, what is the protocol for a road that is part snow/part asphalt (uncovered)?
Thanks.
-Erik
2010 Jeep Liberty Sport 4x4
Dark Charcoal Pearl / Dark Slate Gray
Command-Trac II
Stock...for now
Nitz240d is offline
post #13 of 17 Old 05-19-2010, 07:28 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
As long as there IS snow on that Tight Turn your fine, because the inside wheels will spin slightly faster than the outside wheels which is why you cannot use Part Time 4WD on dry pavement. For roads that are partially covered its kinda tricky, because you shouldnt use it on the dry stuff but you want to on the slippery stuff, if the patches are on a straightaway so when you go over the dry patches and your not turning it shouldnt be an issue but if the dry stuff is on a turn then you should turn off Part Time 4WD and enable it when your out of the turn
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #14 of 17 Old 05-19-2010, 10:33 AM
Nitz240d
2010 KK Liberty
Got it - that's what I figured. Basically you've got to be on your toes in that partial-snow situation (which you should be anyway). I know you're not going to destroy your drivetrain with one dry pavement run, but it's a long-term damage kind of deal so I do want to be careful.
Command-Trac II
Stock...for now
Nitz240d is offline
post #15 of 17 Old 05-19-2010, 11:12 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Exactly
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
Driving lights cnypt KK Liberty Forum 3 12-23-2015 10:28 PM
First Time in th Snow- Griding Noise??? mike79 KK Liberty Forum 13 12-22-2009 11:57 AM
