This might seem small to some but it has become a problem for me.
How do you replace the driving light bulb on a 2008 Liberty Limited on the drivers side?
I can see and access the passenger side light but cannot get to the drivers side.
Is there anyway I can get to it without removing the battery?
The way I did it was to remove the grille and unscrew the headlight housing from the truck. Very easy to replace the bulb that way. Not too difficult to remove the grille at all.
Make sure the rubber grommet from the old bulb is not still stuck in the headlight housing. There is not room for two rubber grommets when you go to install the new bulb.
I did mine a while back by taking the grill and then the headlight out. Super easy. When I went to put everything back together it all went in and everything works but the orange clips that lock the plug into the bulb wont lock into place no matter what I try. Has this happened to anyone else?
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
