drivers window removal help! - JeepForum.com
post #1 of 7 Old 04-09-2015, 10:00 AM Thread Starter
akira19
2008 KK Liberty
So my wife went to lower the window this morn and the cables seem to have come off the window mechanism. How the heck do you remove the whole setup??? Ive got the panel off and motor out and the cables were piled up and crimped. I understand how they loop over the 2 pulleys and work in reverse of each other just dont know how to remove the panel/track system or unclip it from the lock setup. This thing has been a nightmare since a rearender and it going to a shop tomorrow but I cant drive it there like this
akira19 is offline
post #2 of 7 Old 04-09-2015, 10:53 AM
NAMoulton
2010 KK Liberty
Most window regulators are riveted into the door panel. Meaning you'll have to drill out the old rivets. I've done temp fixes where you push the window up and then tape the window shut via packaging tape until someone you trust can do it.
Custom/JBA 4.5" Lift-16x8 M13 Rims-265/75 Pro Comp MT2s-Yukon 4.56s-Rear Ox Locker-Front DTT
NAMoulton is offline
post #3 of 7 Old 05-08-2015, 07:58 PM
cutprogram
If you have not fixed this yet i will be rebuilding my regulator very soon. I will post pics if you like
cutprogram is offline
post #4 of 7 Old 05-12-2015, 06:05 AM
bchc
I would like to see some pictures if you do this. My rear drivers side door has this issue, and right now I've just got a 2x4 in the door panel holding the window in place.
bchc is offline
post #5 of 7 Old 05-12-2015, 09:05 PM
cutprogram
It was going to be today......but the rain has told me otherwise. Hopefully pull the inner door panel out this saturday
post #6 of 7 Old 05-12-2015, 09:07 PM
cutprogram
I believe the whole track is connected to the inner door panel by way of the glass. not quite sure yet. It does look kind of nightmare-ish
post #7 of 7 Old 06-16-2015, 02:18 PM
magsls1
I replaced mine a while ago so I don't remember all the details off the top of my head, but the window regulator assembly is attached to the black plastic panel under your interior door panel. Removing the glass from it is tricky. There is a small circular black sticker on the plastic panel and you need to remove it and push a screw driver through there with force. That will release the window from the track and allow you to remove the panel. Once you do that you can easily remove the panel and fix or replace as needed.
magsls1 is offline
