Driver's side door lock 2009 Liberty - JeepForum.com
post #1 of 10 Old 05-10-2012, 06:51 AM Thread Starter
Jeff88
My girlfriend's 2009 Liberty recently has a new issue. The driver's side front door won't respond to the keyless entry.
It won't lock or unlock, it will lock and unlock manually.
It is out of warranty on mileage.
Has anyone had this happen and where do I begin looking?
There must be an actuator that does this? Where is it located and how hard is it to get to?
Thanks for any feedback!
Jeff88 is offline
post #2 of 10 Old 05-10-2012, 08:23 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Maybe it's the CAN data bus. Do you have a scan tool/can someone pull a code?
JeepCares is online now
post #3 of 10 Old 05-10-2012, 10:28 AM Thread Starter
Jeff88
No, but I can go get it scanned at Autozone, I think.
What am I looking for as far as codes?
Jeff88 is offline
post #4 of 10 Old 05-10-2012, 11:37 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Maybe I'm getting ahead of myself here.
If you were just going to throw a part at it -
The lock mechanisms are actuated by a reversible electric motor mounted within each door and tailgate. The power lock motors are integral to the door latch units. The power lock motors cannot be adjusted or repaired and, if faulty or damaged, the door latch unit must be replaced.
If you can get codes for free - see what they are - maybe that will help you start your search.
Here are some possibilities on what could be causing the door lock not to work-
(P930) DRIVER DOOR LOCK DRIVER CIRCUIT OPEN
(P930) DRIVER DOOR LOCK DRIVER CIRCUIT SHORT TO GROUND
(P910) DRIVER DOOR UNLOCK DRIVER CIRCUIT OPEN
(P910) DRIVER DOOR UNLOCK DRIVER CIRCUIT SHORT TO GROUND
DRIVER DOOR LATCH
TOTALLY INTEGRATED POWER MODULE (TIPM)
post #5 of 10 Old 05-10-2012, 11:49 AM Thread Starter
Jeff88
DRIVER DOOR LATCH
Are we talking about this part?
OEM 2009-2012 Jeep Liberty KK Drivers Front Left Door Latch 4589467-AG Mopar
Jeff88 is offline
post #6 of 10 Old 05-10-2012, 12:26 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
#2 in the picture?
post #7 of 10 Old 05-10-2012, 03:38 PM Thread Starter
Jeff88
thanks for the info!
Jeff88 is offline
post #8 of 10 Old 05-10-2012, 03:40 PM
scorpionarmor55
2010 KK Liberty
I was just taking a look at my speakers and thought an actual pic of the mechanism would help (right rear door)
scorpionarmor55 is offline
post #9 of 10 Old 05-10-2012, 04:13 PM Thread Starter
Jeff88
Absolutely those pictures help, I have never had the door panels off of this Liberty, so I was wondering all day (she had the Liberty with her) if they were hard to get off or not.
I appreciate you posting those, looks like a fairly simple removal or at least its not buried in the door somewhere.
Jeff88 is offline
post #10 of 10 Old 05-14-2012, 06:48 PM Thread Starter
Jeff88
Ok, so the panel is easy to get off, but I can't get to the mechanism yet.
I had it all apart, it started to get dark and she needs the Jeep tomorrow for work, so I had to put it all back together.
I didn't realize it would get so in-depth or I wouldn't have even started tonight.
Does anyone know what the process is to remove the power window motor? It seems I have to do that in order to get the panel completely off to access the door latch assembly.
I know it has three bolts holding it in, when I remove those, it seems to have tension on it, the last thing I need is for her to not have a power window when I am done!!!
Anyone?
Jeff88 is offline
2009 Liberty reliability wisconsinwalter KK Liberty Forum 9 03-13-2012 04:29 PM
2009 Liberty interior lights stay on "door" alert Jeff88 KK Liberty Forum 8 02-14-2012 02:13 PM
Jeep Liberty KK 2009 LibertyJ KK Liberty Forum 6 05-27-2011 08:02 AM
Inner tie rod Jeep Liberty 2009 KK suzuki_gixxer KK Liberty Forum 15 09-27-2010 02:30 AM
2009 Liberty... Any tow points? AmnWatkins KK Liberty Forum 8 09-21-2010 07:46 PM
