Dreaming about adding several gauges - Page 2 - JeepForum.com
post #16 of 32 Old 02-09-2014, 03:00 PM Thread Starter
Rob K
1995 XJ Cherokee
Originally Posted by fairmont1998 View Post
Look at an Ultragauge. They are pretty awesome and a great price.
http://www.ultra-gauge.com/ultragauge/
Pretty cool and inexpensive. Looks like it will only tell me battery voltage and none of the other things I want.
Rob K is offline
post #17 of 32 Old 02-09-2014, 03:07 PM Thread Starter
Rob K
1995 XJ Cherokee
Anyone know of a list of the things monitored by the KK computer? Is there a certain engine monitor that would work best with a Chrysler product? Seems like a lot of these products are fairly new and they don't have very much information as to which vehicles they will work with and exactly what things they will monitor. Seems like you have to buy one and see what happens. Maybe the companies would let you do a trial run on their product if they didn't know exactly what it will monitor for your specific vehicle.
Rob K is offline
post #18 of 32 Old 02-09-2014, 08:51 PM
Gageraid
2008 KK Liberty
One of the Jeep Gods might know the answer to that, but I really don't think you're going to find what you're looking for.
Good luck though and maybe we'll learn something new.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #19 of 32 Old 02-10-2014, 03:15 AM
fairmont1998
2012 KK Liberty
My Ultragauge tells me boost(and vacuum), fuel rail pressure and as you already saw, voltage. This in on a CRD export model.
Not sure if they can read trans temp or oil pressure from the KK ECU.
2012 KK Cherokee Limited CRD
fairmont1998 is offline
post #20 of 32 Old 02-10-2014, 05:39 PM Thread Starter
Rob K
1995 XJ Cherokee
I did a model and year specific search on their website and came up with a list of monitored parameters. If you just look at their general list of things that they monitor than the list is longer. I might have to contact them to see if they have any specific info for a 2011 Liberty Sport with gas engine. There sight specifically says it won't monitor transmission temp on any vehicle.
Rob K is offline
post #21 of 32 Old 02-11-2014, 07:22 PM Thread Starter
Rob K
1995 XJ Cherokee
Found someone on the forum that has the same 2011 Liberty and has an Ultragauge. Sent a PM so hopefully they respond with some info. I also sent an email to Ultragauge asking if they have a specific list of parameters that the Ultragauge will display for said vehicle. I'd be surprized though, since they have a disclaimer saying all vehicles are different and will display different gauges. Sounds like they don't want to get into vehicle specific info. Also they give you is a list of stuff that it might display. Kind of useless info if you are looking to buy one.
Rob K is offline
post #22 of 32 Old 02-12-2014, 06:39 PM Thread Starter
Rob K
1995 XJ Cherokee
Ultragauge responded by saying to use their gauge estimator tool. Not useful since I already seen it. All it does is give you a list of things that the Ultragauge might monitor for your vehicle.
Rob K is offline
post #23 of 32 Old 02-13-2014, 05:08 PM
jmic0925
2012 KK Liberty
I just ordered an Ultragauge. I've been wanting a Scangauge II, but for the price (80 shipped with horizontal holder) and the blue display I went for the grab.
jmic0925 is offline
post #24 of 32 Old 02-13-2014, 05:16 PM Thread Starter
Rob K
1995 XJ Cherokee
Cool, whenever you get around to hooking it up and learn how to use it can you post a list of things that it actually monitors. It would be quite helpful for everyone since I did a search on the internet and couldn't find a detailed list anywhere.
Rob K is offline
post #25 of 32 Old 02-13-2014, 05:18 PM Thread Starter
Rob K
1995 XJ Cherokee
Also seen on the Ultragauge website that they have a new MX version in very limited supply. It's supposed to "Possibly" monitor transmission temp on some Ford and GM vehicles.
Rob K is offline
post #26 of 32 Old 02-13-2014, 05:21 PM Thread Starter
Rob K
1995 XJ Cherokee
Here's a list of gauges that the Ultra Gauge can potentially display for any vehicle. Taken from their website.
UltraGauge EM can display 76+ possible gauges*. Gauge selection is completely customizable. The actually gauges available are vehicle dependent. If your vehicle supports any of the gauges listed, then the gauge will be available for display by UltraGauge.
UltraGauge currently does not support Manufacturer specific gauges such as Transmission temperature.
Gauge
% Engine Load
Engine Coolant Temperature (F)
Engine Coolant Temperature (C)
Short Term Fuel Trim Bank 1
Long Term Fuel Trim Bank 1
Short Term Fuel Trim Bank 2
Long Term Fuel Trim Bank 2
Fuel Pressure (PSI)
Fuel Pressure (kPa)
Intake Manifold Absolute Pressure (MAP)(PSI)
Intake Manifold Absolute Pressure (MAP)(kPa)
RPM
MPH
KPH
Timing Advance
Intake Air Temperature (F)
Intake Air Temperature (C)
Mass Air Flow Sensor 1 (g/s)
Absolute Throttle Position 1 %
Bank 1 0xygen Sensor 1 Voltage
Bank 1 0xygen Sensor 2 Voltage
Bank 2 0xygen Sensor 1 Voltage
Bank 2 0xygen Sensor 2 Voltage
Run time since last start (hours:mins)
Miles traveled with Check Engine Light On.
Kilometers traveled with Check Engine Light On.
Fuel Pressure (Diesel & Direct Injection) (PSI)
Fuel Pressure (Diesel & Direct Injection) (10kPa)
Bank 1 Wide 0xygen Sensor 1 Lambda
Bank 2 Wide 0xygen Sensor 1 Lambda
EGR Flow %
EGR Flow % Error
Evaporative Purge %
Fuel Level % of full
Number of Warm-ups since Check Engine Light Cleared
Miles traveled since Check Engine Light Cleared
Kilometers traveled since Check Engine Light Cleared
Evaporative System (PSI)
Evaporative System (Pa)
Barometric Pressure – Inches of Mercury (inHg)
Barometric Pressure – Inches of Mercury (kPa)
Catalytic Converter Bank 1 Sensor 1 Temperature (F)
Catalytic Converter Bank 1 Sensor 1 Temperature (C)
Catalytic Converter Bank 2 Sensor 1 Temperature (F)
Catalytic Converter Bank 2 Sensor 1 Temperature (C)
Catalytic Converter Bank 1 Sensor 2 Temperature (F)
Catalytic Converter Bank 1 Sensor 2 Temperature (C)
Catalytic Converter Bank 2 Sensor 2 Temperature (F)
Catalytic Converter Bank 2 Sensor 2 Temperature (C)
Battery Voltage (Measured by ECM)
UltraGauge Battery Voltage (Measured by UG)
Load absolute %
AFR Commanded Ratio
Relative Throttle Position %
Outside Ambient Air Temperature (F)
Outside Ambient Air Temperature (C)
Absolute Throttle Position 2 %
Accelerator Pedal Position 1 %
Accelerator Pedal Position 2 %
Command Throttle Position %
Boost Pressure, (Relative Pressure) (PSI)
Boost Pressure, (Relative Pressure) (kPa)
Brake Horsepower 1
Brake Kilowatts 1
Torque 1 (ft lbs)
Torque 1 (N.m)
Brake Horsepower 2
Brake Kilowatts 2
Torque 2 (ft lbs)
Torque 2 (N.m)
Mass Air Flow Sensor 2 (g/s)– Calculated
Instantaneous MPG
Instantaneous KPL
Instantaneous L/100Km
Average MPG – General
Average KPL – General
Average L/100Km – General
Average MPH – General
Average KPH – General
Run Time – General
Miles – General (miles)
Kilometers – General (miles)
Fuel Used – General (gallons)
Fuel Used – General (liters)
Average Gallons/Hour - General
Average Liters/Hour - General
Fuel Level (gallons)
Fuel Level (liters)
Instantaneous Gallons/hour
Instantaneous Liters/hour
Distance to Empty (miles)
Distance to Empty (kilometers)
Time to Empty
Volumetric Efficiency (MAP vehicles only)
General Trip Gauges
Average MPG
Fuel Used
Average Gallons/hour
Average MPH
Distance (miles)
Run Time
Average KPH
Average KPL
Average L/100Km
Liters Used
Average Liters/Hour
Distance (kilometers)
Short Trip Gauges**
Average MPG
Fuel Used
Average MPH
Distance (miles)
Run Time
Average KPH
Average KPL
Average L/100Km
Liters Used
Average Liters/Hour
Gauges new to UltraGauge EM v1.2 are shown in blue. The EM v1.2 began shipping on 6/27/12 in the USA and on 7/9/12 Internationally
The Classic and earlier EM versions supported gauges
* Actual available gauges are vehicle dependent.
** Short trip gauges reset at each ignition off.
While not comprehensive, the Gauge Availability Estimator can potential provide an estimate of the gauges available for your vehicle. The estimator can be found here: Gauge Availability Estimator
Rob K is offline
post #27 of 32 Old 02-13-2014, 05:23 PM Thread Starter
Rob K
1995 XJ Cherokee
Here is the list of gauges that can possibly be displayed for a 2011 Liberty Sport. Taken from the website using their gauge estimator tool.
Vehicle Gauge Availability Estimator
(THIS IS NOT A COMPATIBILITY ESTIMATOR, PLEASE READ THE FOLLOWING)
This utility estimates the gauges that may be available for a vehicle based upon Year, Make, Model & Engine Size. Use only for estimation purposes, results not guaranteed.
This utility is by no means comprehensive and is a work in progress, and your vehicle may or may not be listed. If your vehicle is not listed, it does not mean that your vehicle is not supported. It only means that currently this utility has no information about your specific vehicle. Most 1996 and newer ODBII-compliant vehicles are supported by UltraGauge. More on compatibility here: Compatibility
If your vehicle is not listed, try like models from other years.
Vehicle Matches: 1
Vehicle #1
Manufacture Date: 07/2011 Transmission: Automatic Protocol: 11-bit CAN
  • Open/Closed Loop Emissions Status
  • Percent Engine Load
  • Engine coolant temperature (F)
  • Engine coolant temperature (C)
  • Short Term Fuel Trim Bank 1
  • Long Term Fuel Trim Bank 1
  • Short Term Fuel Trim Bank 2
  • Long Term Fuel Trim Bank 2
  • Intake Manifold Absolute Pressure (MAP) PSI
  • Intake Manifold Absolute Pressure (MAP)(kPa)
  • RPM
  • MPH
  • KPH
  • Ignition Timing Advance
  • Intake Air Temperature (F)
  • Intake Air Temperature (C)
  • Absolute Throttle Position Percentage
  • Bank 1 Oxygen Sensor 1 Voltage
  • Bank 1 Oxygen Sensor 2 Voltage
  • Bank 2 Oxygen Sensor 1 Voltage
  • Bank 2 Oxygen Sensor 2 Voltage
  • ECM Run Time
  • Distance traveled with Check Engine Light on (miles)
  • Distance traveled with Check Engine Light on (km)
  • Commanded EGR Flow Percent
  • Commanded EGR Flow Error Percent
  • Commanded Evaporative purge Percent
  • Fuel Level Percent (Auto fuel fill-up detection also suppported)
  • Number of warm-ups Since Check Engine Light cleared
  • Distance traveled since Check Engine Light cleared (miles)
  • Distance traveled since Check Engine Light cleared (km)
  • Barometric Pressure (inHg)
  • Barometric Pressure (kPa)
  • Catalytic Converter Bank 1 Sensor 1 Temperature (F)
  • Catalytic Converter Bank 1 Sensor 1 Temperature (C)
  • Catalytic Converter Bank 2 Sensor 1 Temperature (F)
  • Catalytic Converter Bank 2 Sensor 1 Temperature (C)
  • Battery Voltage
  • Relative Throttle Position Percentage
  • Ambient Air Temperature (F)
  • Ambient Air Temperature (C)
  • Accelerator Position 1 Percentage
  • Accelerator Position 2 Percentage
  • Commanded Throttle Position Percentage
  • Boost Pressure, (Relative Pressure) (PSI)
  • Boost Pressure, (Relative Pressure) (kPa)
  • Brake Horsepower 1
  • Brake Kilowatts 1
  • Torque 1 (ft lbs)
  • Torque 1 (N.m)
  • Brake Horsepower 2
  • Brake Kilowatts 2
  • Torque 2 (ft lbs)
  • Torque 2 (N.m)
  • Volumetric Efficiency
  • UG Battery voltage
  • Mass Air Flow 2, Calibrated/Calculated
  • Instantaneous MPG
  • Intantaneous Gallons/Hour (GPH)
  • Instantaneous KPL
  • Intantaneous Liters/Hour
  • Instantaneous L/100km
  • Distance to Empty(DTE)(miles)
  • Distance to Empty(DTE)(km)
  • Time to Empty (TTE)
  • Fuel Level (gallons)
  • Fuel Level (liters)
  • Oil Distance(miles)
  • Oil Distance(km)
  • Service Distance(miles)
  • Service Distance(km)
  • General Purpose
  • Average MPH
  • Average MPG
  • Average Gallon/Hour (GPH)
  • Fuel Used (gallons)
  • Run Time
  • Distance (miles)
  • Average KPL
  • Average L/100km
  • Average KPH
  • Average Liters/Hour
  • Fuel Used (liters)
  • Distance (km)
  • TRIP GAUGES
  • Run Time
  • Average MPH
  • Average MPG
  • Fuel Used Gallons
  • Average Gallon Per Hour (GPH)
  • UltraGauge Internal Temperature (F)
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
  • UltraGauge Internal Temperature (C)
  • SHORT TRIP GAUGES
  • Run Time
  • Avergage MPG
  • Average gallons/hour
  • Average MPH
  • Distance (miles)
  • Average KPH
  • Avergage KPL
  • Avergage L/100km
  • Liters Used
  • Distance (km)
More Info on available gauges
UltraGauge Compatibility
*** PLEASE NOTE ***
This utility is for the UltraGauge EM only.. The UltraGauge Classic has been discontinued
Rob K is offline
post #28 of 32 Old 02-14-2014, 07:18 AM
jmic0925
2012 KK Liberty
The MX version doesn't work with the KK I believe cuz we have a ISO-9141 port which doesn't support the MX. I really wanted the EM plus but I didn't need the performance stats (60 time, breaking times) even tho I really wanted it. I'm not racing my KK anytime soon nor going to be customizing for that (only plan for the CAI). Then after shipping and docking accessory it still came out to 80. I'm excited for a new toy since I finally started some work again and will have some money.
jmic0925 is offline
post #29 of 32 Old 02-14-2014, 10:43 AM
carlosburitica
2010 KK Liberty
here is my idea
carlosburitica is offline
post #30 of 32 Old 02-15-2014, 11:42 AM
s2killa
2011 KK Liberty
i have the autometer Ecometer dont got all those options just gives me looks ahahaha but really gives me MPH RPM Instantaneous MPH and Average MPG, with what your looking for the Scangauge is more than enough
Instagram-DHR_S2KILLAA
11 Liberty KK l Daystar 2" l Rock Crawler 15x8 3.75" l M/T Baja MTZ 31x10.50
s2killa is offline
