Door unlock issue - JeepForum.com
post #1 of 10 Old 02-23-2014, 10:57 AM Thread Starter
qwas37
2010 KK Liberty
Door unlock issue
I'm having an issue with my doors unlocking. With the remote and from the door unlock switch, only the drivers door will unlock. The parking lights flash twice when I attempt to unlock or press twice to unlock passenger doors but that's it
qwas37 is offline
post #2 of 10 Old 02-23-2014, 11:25 AM
wjkrostek
2012 KK Liberty
I have a different issue maybe some one can help me with. When I unlock the door with the key the horn blasts until I put the key in the ignition. I'm sure its an anti theft issue but how do I turn it off? Does your do that too or is it just in mine? Thanks.
wjkrostek is offline
post #3 of 10 Old 02-24-2014, 12:54 PM
Attorney58
2011 KK Liberty
you should change it from the personal settings. When you turn it off, you will unlock all the doors as you use one button from key
Attorney58 is offline
post #4 of 10 Old 02-24-2014, 11:07 PM
AtTheHelm
I have the same problem, but it happens only after a couple hours of driving. It goes back to normal for me after a couple hours sitting. The real pisser about this is not being able to open the back gate. Pretty sure its all controlled by the tipm and requires the dealership to fix it.
AtTheHelm is offline
post #5 of 10 Old 02-26-2014, 09:28 AM Thread Starter
qwas37
2010 KK Liberty
What is a tipm?
qwas37 is offline
post #6 of 10 Old 02-26-2014, 09:46 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Totally Integrated Power Module
Very basically - all the power goes to the Jeep through the TIPM (from the battery.)
It has cartridge fuses, mini-fuses and relays in it.
JeepCares is online now
post #7 of 10 Old 03-15-2014, 12:41 AM
Nkm46290
Hi everyone. I'm new to the forum and also a recent owner of an 09 liberty. I have been havering problems with my door locks engaging on there own. Both parked with no key in it and while driving. Also the rear gate had a new latch mechanism put in less then a month ago because it read open on the dash and even made my interior lights stay on constantly. It has recently started doing this again over the last few days. Any help would be greatly appreciated.
Nkm46290 is offline
post #8 of 10 Old 03-16-2014, 11:17 AM Thread Starter
qwas37
2010 KK Liberty
An update...
My unlocking problem is the tipm. Unbeleivably, it had to be replaced to the tune of around $300.
My advice to you would be to get rid of the jeep as soon as possible as these things have the poorest engineering of just about anything I've experienced.
I bought a super clean 2010 Liberty with 105,000 miles on it for my daughter six months ago because its what she really wanted. Come to find out, the heads on a 3.7 are notorious for cracking or blowing head gaskets, I'm replacing mine now. A $2400 job. The rear pinion seal is out and the doors won't unlock.
In comparison, my brother and I both bought 10 year old Mercedes ML430 and a ML 320 with 100,000 plus miles on them, they were built in Alabama. They are the easiest cars you'll ever work on and completely reliable. Four wheel drive 8 and 6 cylinders and parts are readily available.
qwas37 is offline
post #9 of 10 Old 03-16-2014, 11:39 AM
Nkm46290
Oh wow. Thanks for the advice. I'm stuck with mine. Just got it in August so far from paid off. Looks like I'm stuck with yet another money pit. I already put $800 into the water pump thermostat and gate latch.
Nkm46290 is offline
post #10 of 10 Old 03-16-2014, 07:05 PM
2012JETLIMITED
I'm having an unlocking issue as well. I'll unlock my jeep with the key fod everything thing opens up but the drivers door stays locked? It will open when I use the key tho, any ideas? It's happened 3x now and my warranty is up in a few hundred miles. Just like some input before I hear the dealerships b/s story.
2012JETLIMITED is offline
