Cylinder 5 misfire help - JeepForum.com
post #1 of 29 Old 02-13-2014, 03:05 PM Thread Starter
jarheadv12
Hello all! I just got my Liberty back from the body shop and the check engine light was on. I had them check it and they said it was a cylinder 5 misfire code. They told me to not worry about it, they said it's probably just from being moved short distances in and out of the garage so many times. But I've been driving it for a day now and it still has the check engine light on and at idle it stutters, and shakes. So there is obviously something still wrong with it. I need help fixing the problem as cheaply as possible since I am a broke college student. Any input would be greatly appreciated!!
jarheadv12 is offline
post #2 of 29 Old 02-13-2014, 03:15 PM
RENE65
2008 KK Liberty
A bit mor info would help,what year Libby,millage ,last time plugs changed ?
RENE65 is offline
post #3 of 29 Old 02-13-2014, 03:26 PM
Gageraid
2008 KK Liberty
Def need the mileage. Prob just need plugs and possibly coils if that doesn't fix it.
Spark plugs every 25-30K.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #4 of 29 Old 02-13-2014, 03:32 PM Thread Starter
jarheadv12
It's a 2009 and it has 55k miles. I don't know when the plugs where changed last, I bought the Liberty off of my grandfather who got his license taken away.
post #5 of 29 Old 02-13-2014, 03:39 PM
RENE65
2008 KK Liberty
Plugs are due every 30,000 miles,you are probably due for the second time around.Make sure you use original NGK copper core plugs,They are the cheapest and are the one that will work best.Also you may also want to check your air filter to check if its not full of dirt or débris from the body shop.
RENE65 is offline
post #6 of 29 Old 02-13-2014, 03:40 PM
Robert0069
Lifter
Robert0069 is offline
post #7 of 29 Old 02-13-2014, 03:42 PM
RENE65
2008 KK Liberty
Lifter would usually cause a loud clacking noise.
RENE65 is offline
post #8 of 29 Old 02-13-2014, 03:48 PM
Robert0069
Some times the follower lands clear of the valve spring
post #9 of 29 Old 02-13-2014, 04:00 PM
Robert0069
What tools do you have ? And I'm sure we all can help you get up and going cheap. RENE65 yes I agree with you 100% and I have seen them do both.
post #10 of 29 Old 02-13-2014, 04:01 PM
Robert0069
Well unless it's a dropped seat
post #11 of 29 Old 02-13-2014, 05:20 PM
RENE65
2008 KK Liberty
Lets not scare Jaeheadv12 right away, be positive , a new set of plugs will fix it cheap
RENE65 is offline
post #12 of 29 Old 02-13-2014, 05:55 PM Thread Starter
jarheadv12
Thank you all for your input!! After many phone calls and arguments I got the body shop to cut me a check to go to the dealer and get the problem fixed! This forum and it's users are absolutely fantastic!! I plan to post any modifications that I do! But don't count on a lot, money is tight!
post #13 of 29 Old 02-13-2014, 06:10 PM
Robert0069
Post the fix please !
post #14 of 29 Old 02-13-2014, 06:21 PM
LKWJEEPER
2009 KK Liberty
I'd bet it's a ignition coil or plug.
Sent from AutoGuide.com Free App
LKWJEEPER is online now
post #15 of 29 Old 02-13-2014, 10:13 PM
Gageraid
2008 KK Liberty
Without a doubt.
I bet he's on the original plugs...
OME lift
Gageraid is offline
