-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   CV Joint Problems after lift Install (http://www.jeepforum.com/forum/f292/cv-joint-problems-after-lift-install-1520265/)
shawnicles 05-07-2013 08:24 PM
3 Attachment(s)
Hey Guys,
So I am having some issues with my CV joints after I installed my lift. As some of you know (rescue, toddmud, Benjamin) I have been having some issues with the RRO lift that I have purchased. They initially sent me too soft of front coil springs which was causing my control arms to hit the top of the pockets before they could touch the bump stops. They addressed the issue by sending my brand new struts, pre assembled with heavier springs.
I got the new ones and put them on Sunday. Everything went together pretty smooth but after the install and we went to go test drive and flex it a bit we noticed my CV Joint on my drivers side was knocking a bit on some movement. All the other control arm issues were resolved with the heavier springs and the JBL bump stop extenders I purchased.
I brought it into the dealership today because the cv joint would be covered under warranty and I wanted to get to it before my warranty ran out. Once they got it on the hoist they called me and said that the CV Joint's angle is way too much and that the bottom of my strut is rubbing on the boot, which in turn ripped the boot and then spit out grease everywhere. Now the first picture below is the vehicle on a hoist so everything was hanging with the tires on. Second and third pictures is the front right tire at full lock both ways sitting on the ground in a normal position when I initially got the lift on with the softer springs 2 months ago so that is why there is no grease.
All of that grease in the first picture was since Sunday to Tuesday. When I took the soft ones off there was no grease anywhere and they were on for 2 months.
Does anyone have any experience with this? There has to be something installed wrong or something else because having essentially the same part in the front for two months didn't cause any issues with the CV Joints. Then I put heavier springs in the front and 2 days later basically both cv joints and boots are shot. I just don't see how 'the lift kit' is at fault. I am honestly hoping there is some type of user error here in the installation.
Obviously I am looking for some serious help on this one because I am the only person in the city with a lifted KK and no shops or dealerships have experience with any lifts period on this vehicle. I am getting fed up with this thing and just want to take it out in the woods and drive it like a jeep is made to be driven. One thing after another is holding me back.
Thanks to everyone for their responses.
AtTheHelm 05-07-2013 09:41 PM
Something looks weird in the first pic, the shock looks way off to one side in the spring. Are you using their daystar copy top plates? Did they use the proper sequence if bushings and washers when assembling the shocks and springs. The thing about those top plates is they don't put enough preload on the springs.
Also is it possible that both inner cv boots got nicked or pinched during installation?
I can't see how the clevis fork would contact the cv boots especially during normal driving.
shawnicles 05-07-2013 09:55 PM
6 Attachment(s)
I just went out and took a couple more picture since the top picture was a little skewed. The first two are the left and right cv joint on a fairly flat surface. There is an angle but not much. The second and third are just showing the flex I put on the suspension and the last two are showing how the cv joints are sitting during that flex. Notice all that grease, I am about to cry!!! haha The struts came pre assembled so I just had to un bolt them and bolt them back in. It could be possible that the boots got pinched during install for sure. Do you think these angles of the cv joints are OK.
Could someone get under their jeep and take a picture of theirs? Preferably someone with a lift in it? and someone that is stock so I have a point of reference to see if the difference is great?
tjkj2002 05-07-2013 09:56 PM
Between the 1st and 3rd pic your UCA balljoints are installed wrong(1st pic).Who's UCA's do you have? JBA or RRO's?
AtTheHelm 05-07-2013 10:12 PM
Here's how mine sits. Its been that way for 26,000 miles and no problems. The clevis fork changed for 2010 thats why it looks different than yours.
http://i748.photobucket.com/albums/x...psf14fd699.jpg
shawnicles 05-07-2013 10:31 PM
AtTheHelm - Is yours lifted? I'm assuming so but I just want to be 100% certain.
tjkj2002 - The 3rd pic on my initial post you are right the UCA's were installed wrong and it's been fixed a couple months ago when they were initially installed. The first pic in my second post they were installed as instructed by RRO. Is that what you meant or do you think they are still installed wrong? They are RRO UCA's, see below. I just didn't install their bump stop extenders because I liked the teraflex ones better.
http://www.rocky-road.com/media/insane_arm.jpg
AtTheHelm 05-07-2013 10:40 PM
Yes ome 927s
tjkj2002 05-08-2013 06:34 AM
Originally Posted by shawnicles (Post 15404037)
They are RRO UCA's
That is most likely your whole issue.
shawnicles 05-08-2013 07:12 AM
I looked at the difference between the RRO UCA's and JBA's there is hardly any difference. In fact, when I called JBA to order rear coil springs and bump stop extenders from them Brian I believe his name was even mentioned after we got shooting the ***** that they are pissed that RRO copied their design and they are almost identical.
Easiest way to make sure is to check though. Benjamin just installed a Silver edition of JBA's lift. Do you mind taking some comparable photos to my second set on the flat surface and see how yours sit? If anyone else that has a JBA silver lift or comparable can take a picture like AtTheHelm just on the driveway, it would be much appreciated.
I don't mind spending the extra money to get JBA UCA's but before I just go buy it I need to see a little evidence.
tommudd 05-08-2013 12:53 PM
There is a huge difference in copying a design and copying it and making it work
I could copy say an ARB bumper , but will it look and fit as well as the original ARB? heck no since I'm not a full time welder/ fabricator same with RRO..............:rolleyes:
_benjammin 05-08-2013 12:59 PM
Wheels turned all the way to the left.
Driver's side:
https://lh5.googleusercontent.com/-3...UNSET%255D.jpg
https://lh4.googleusercontent.com/--...UNSET%255D.jpg
Passenger's side:
https://lh6.googleusercontent.com/-u...UNSET%255D.jpg
https://lh5.googleusercontent.com/-D...UNSET%255D.jpg
shawnicles 05-08-2013 01:33 PM
toddmudd I totally agree what you are saying for sure and it's great logic.
benjammin has the JBA UCA's and it looks like he has the same angle as mine, I don't see any difference. I asked him to upload some of the UCA so I can see if there is a design difference as well. I dont mind spending the 400 bucks on the JBA UCA's and then really just throwing the RRO ones out but I just want to see some sort of difference.
I sent the same pictures to my dealership and got their suspension person to take a look and he doesn't see anything really wrong with the angle at all and says that is typically what happens when a lift is installed. So the CV's will be replaced tomorrow and I think all of the issues will be sorted out.
Alex2014 10-18-2014 02:49 PM
HELLO. Im a begginer
I am interested in a lift kit 4 "for my 2009 Jeep Liberty kk.
I have a question about the CV. Lifting these 4 "to the CV will not get too angled, which could cause problems? For example, if I need to use lower gears, because of the CV being more angled, will not cause me problems or damage it?
lfhoward 10-18-2014 05:05 PM
I have the 4 inch JBA adjust a strut kit and have it set to 22 inches in front (stock is 18). I've had it installed for 33,000 miles so far and it is great. I had an issue with my passengers side CV and intermediate shaft within the first 3000 miles, but I wonder if that was going to go bad anyway even without the lift. I replaced it with another OEM CV and intermediate shaft from a junkyard KK that was rear-ended at 25,000 miles. I have had no CV issues since replacing it, even with 30,000 more miles lifted.
Many others are running 4 inches of lift, both with KJs and KKs. Tommudd's KJ has a 4.5 inch lift on it and I think he has only replaced one CV one time, even with 180,000 miles lifted (IIRC; I'm sure he will correct me if I'm wrong).
tommudd 10-18-2014 10:54 PM
Anytime you raise above stock height you may have issues, its just that plain and simple. But using some common sense and not beating it to death the CVs will take quite a bit . NOW if you already have 100,000 miles on one of course parts wear out, stock height or lifted.
Keep it at 3.5 inches and not over 4 and you shouldn't have too many issues as many are running at that height. My KJ ( same front suspension) has been in the 4plus inch range for somewhere around 160,000-170,000 at least. Been lifted about 190,000 miles total. In that time I've only replaced the left side once and that was with 190,000 on the KJ. ( 170,000 lifted miles)
Using lower gears and having CVs that are more angled have nothing to do with one another. You need to regear when you get up in the 30-32 inch tall tire range , not because of lift
The time now is 01:35 AM.
