creaking door hinges - JeepForum.com
post #1 of 3 Old 07-31-2016, 08:07 PM Thread Starter
bgonzo
I have a jeep liberty with very creaking and popping door hinges. The rollers are seized up and the cam is just grinding across the surface.
I'm just curious if there is a way to fix this without taking the door all apart.
bgonzo is offline
post #2 of 3 Old 08-01-2016, 06:48 AM
dellis
2005 WK
If you have closed hinges, silicon spray will work its way down into the parts (spray and then open/close to work it in). If you have open hinge components, then white lithium grease will quiet your doors.
Both will need to be reapplied every 4-6 months, and white lithium grease tends to gunk up with dirt.
1998 ZJ, 4.0 // 2005 WK Limited, 4.7 // 2008 KK 3.7
dellis is offline
post #3 of 3 Old 08-01-2016, 06:36 PM Thread Starter
bgonzo
OK Thanks, Ill give it a try
bgonzo is offline
