Coolant Question/Preventative Issue - JeepForum.com
post #1 of 11 Old 09-16-2013, 10:46 AM Thread Starter
pakman325
So I have been doing some basic work on my KK the last couple weeks and have notice that my coolant reservoir is low. Engine temps are normal and there are no indicator lights suggesting a problem, but I would like to know how normal this is.
Do coolant reservoirs need to be refilled on occasion? Should I assume that there is a leak?
Under the car recently, I have noticed condensation from the A/C, but it is usually pretty small and I haven't thought much of that.
Any idea how concerned I should be or what I can do about this?
pakman325 is offline
post #2 of 11 Old 09-16-2013, 01:09 PM
LKWJEEPER
2009 KK Liberty
How low are you talking about? Have you had the fluids flushed and it wasn't ever brought up to the correct level? If you had an issue you would notice the fluid level decreasing fairly quickly.
I had a 2001 Impala with a cracked head gasket. I noticed I was having to fill up coolant every other month.
LKWJEEPER is offline
post #3 of 11 Old 09-16-2013, 01:15 PM Thread Starter
pakman325
This vehicle was new to me at 113k miles. Now 3,000 later, I noticed it. Never knew the tank to be especially full though. Everything ran at-temp and smoothly (and continues to do so), but I just want to make sure this isn't something that will become an issue in the future, and if it might, how I can rectify it.
The level is down to the very lowest scallop in the reservoir. It appears to be steady from that point though.
post #4 of 11 Old 09-16-2013, 04:51 PM
lfhoward
2008 KK Liberty
I would fill it up to halway between the Max and Min lines, using HOAT coolant (as the owners manual states), and keep an eye on it. I think coolant slowly evaporates out of the coolant bottle (over the years), as the lid is not exactly airtight. I had to fill mine up a bit after I bought it, but haven't had trouble since. If you really do have an engine problem, you'll be filling it every month or sooner. I had an XJ with a cracked head and that's what happened. I don't expect you'll have a problem like that. You could always try replacing your radiator cap, too, and see if the loss stops.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #5 of 11 Old 09-16-2013, 04:52 PM
lfhoward
2008 KK Liberty
Keep in mind too that coolant expands when hot and contacts when cold. So the level will be different in your coolant bottle depending on whether the engine is warmed up.
lfhoward is offline
post #6 of 11 Old 09-17-2013, 08:11 AM Thread Starter
pakman325
Thanks for the advice. I don't think of it as a problem... yet. And I'm not sure that I could even definitively call it a loss of coolant as I haven't seen it decrease (and certainly not to any measurable degree).
I'll probably look into filling that this weekend.
post #7 of 11 Old 09-17-2013, 08:14 AM
LKWJEEPER
2009 KK Liberty
You would know it if you had a coolant leak.. maybe you wouldn't see the drip, but if you had an issue. I'm fairly certain you would know about it.
post #8 of 11 Old 09-17-2013, 01:48 PM Thread Starter
pakman325
That's the way I thought about it, but I am one of those people who doesn't let small issues like that go easily. I'll have an aneurysm one day.
post #9 of 11 Old 09-17-2013, 02:34 PM
tommudd
2004 KJ Liberty
But yet you say
"I'll probably look into filling that this weekend."
so you're not really too concerned . No matter if I thought if it was leaking or not I'd be filling it to the required level today
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #10 of 11 Old 09-17-2013, 09:21 PM
Ted15
2010 KK Liberty
Mine was low a while ago as well. I since received a letter from mopar for a recall on water pumps with a W on it. I don't know if you'd be covered but it's worth looking into.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #11 of 11 Old 09-21-2013, 09:40 PM Thread Starter
pakman325
Originally Posted by tommudd View Post
But yet you say
You would have to understand the context of my life right now. Prep football coach (in season) and school teacher. I don't get home until well after 8 at night so there is no service department I could even buy the HOAT fluid from even open during my available hours.
Anyway, I topped off today, got about 150 miles in without seeing a single drop puddle up below the vehicle or anything spraying inside that might indicate a bad hose.
Tonight's cold sit will be a test, but it would seem that it was just due to long term evaporation and negligence by the previous owner.
Thanks for the advice guys!
Now to look into hitch receivers and new tires...
