Cobra 75 WX ST - JeepForum.com
post #1 of 9 Old 01-04-2013, 02:06 PM Thread Starter
rescue575
2011 KK Liberty
Cobra 75 WX ST
Hey guys....to any and all who have installed the Cobra 75 in their KK.....i am planning on installing the junction box in the shift knob compartment. My question. Is where did you guys wire it up?? Did you wire it direct or connect a auxiliary plug for the outlet? If you did wire it directly, where, what and how did you connect them?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #2 of 9 Old 01-04-2013, 06:04 PM
KK4x4
2009 KK Liberty
I wired mine to a thick blue wire under the dash on the drivers side...if you use that BE CAREFUL there is a thinner blue wire. Don't know what the thinner one does but I know the one I'm using works and the key has to be in the position where it's before you start the truck(don't remember if its on or run)and it works just fine
KK4x4 is offline
post #3 of 9 Old 01-04-2013, 06:43 PM Thread Starter
rescue575
2011 KK Liberty
Wouln't happen to have any pictures would ya?
2011 Liberty Sport
post #4 of 9 Old 01-05-2013, 05:51 PM
KK4x4
2009 KK Liberty
Well I could but its too dark now and don't know how to post pix on here yet
KK4x4 is offline
post #5 of 9 Old 01-11-2013, 10:19 PM
lfhoward
2008 KK Liberty
I wired mine to an auxiliary fuse panel that I put under the dash, which draws power directly from the battery. Here is a writeup I made over on LOST. http://www.lostjeeps.com/forum/phpBB...p?f=45&t=72386
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #6 of 9 Old 04-07-2013, 06:53 AM Thread Starter
rescue575
2011 KK Liberty
great idea, however i am not very electronically inclined so im not sure i would even attempt this. however, i did wire my lights up........and get this....they actually turned on! I was simply AMAZED!
2011 Liberty Sport
post #7 of 9 Old 04-07-2013, 01:51 PM
lfhoward
2008 KK Liberty
Excellent!
lfhoward is offline
post #8 of 9 Old 04-07-2013, 02:21 PM
lfhoward
2008 KK Liberty
You can run both hot (+, red) & ground (-, black) wires direct from the radio to the Jeep battery through the circular rubber grommit that is in the firewall behind and to the left of the steering wheel. Wiring your radio direct to the battery will eliminate electrical interference from other circuits that you might otherwise tap into. I had my CB wired direct to the battery before building my fuse panel, and I had an in-line fuse holder (5 amp fuse will do) on the power wire a few inches from the battery just as a precaution.
The reason I built my aux fuse panel was that I eventually had too many accessories all wired to the battery this way (CB, trailer lights, additional power outlet, etc.) and wanted to simplify what had become a can of worms.
lfhoward is offline
post #9 of 9 Old 04-07-2013, 06:03 PM Thread Starter
rescue575
2011 KK Liberty
I hear ya there. Thats pretty much how i ran yhe radio. I grounded it under the shifter panel and ran the pos feed through that gromit that you are referring to. Eventually i want to run the pos feed to a wire under the dash when i can figure out which one
I ran the bumper lights to the fuse panel under the hood instead of battery simply because i didn't really want wires wrapped around the battery.
2011 Liberty Sport
