Check Engine Light P0456 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Check Engine Light P0456
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits BLACK FRIDAY SPECIALS!! You asked, we deliver!Rough Country Lift Kits and Parts!
Unread 09-29-2010, 06:03 AM   #1
Elt31987
Elt31987's Avatar
2008 KK Liberty
So got my first CEL since i bought it 2 1/2 Years ago. P0456. After reading its referring to a small leak in the Evaporation System. First everyone says to check the Gas Cap which i turned off the engine, Took the cap off, put it back on and made sure it clicked a few times. The cap is a Mopar Locking Cap that I've had since i bought the Jeep. After removing the cap and putting it back on the light is still on after i drove about 22 miles to work. I don't know how long it takes for the code to disappear if that was the issue but the light is still on. So basically I'm going to hope its off when i leave work today and if not ill put my girlfriends Locking Mopar Cap from her Patriot on mine and see what happens. Any other suggestions to look for?
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline   Reply With Quote Quick reply to this message
Unread 09-29-2010, 01:18 PM   #2
richd
2008 KK Liberty
There are 2 causes of PO456,I would swap caps to see if that helps,If not the there a small leak somewhere in the EVAP:
  • Fuel tank cap is damaged, loose or the wrong part number
  • Small leak present somewhere in the EVAP system
Here is how to reset your code:
To reset your engine codes:
Remove the negative terminal of your battery (10mm wrench).
Turn your ignition key to START and hold it there for about 15 seconds.
Turn your ignition key to OFF and remove it.
Connect the negative terminal of your battery.
Start but do not hit the throttle. Idle for about 10/15 seconds then turn off.
Restart the truck and drive as usual. It will take at least 12 starts and 48 miles to fully retune the computer. Hard Codes leave a shaddow for 40 full cold starts.
richd is offline   Reply With Quote Quick reply to this message
Unread 09-29-2010, 05:29 PM   #3
Elt31987
Elt31987's Avatar
2008 KK Liberty
So i inspected the Evap Box and hoses and didnt see any holes or tears etc. BUT, i could smell gas from the Cap so i think its leaking. So i disconnected both battey terminals for 30 minutes and threw my original Gas Cap on that i found laying around and so far so good. Ill keep you guys updated over the next week. Wish me luck.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Unread 09-29-2010, 06:04 PM   #4
richd
2008 KK Liberty
Your doing it the right way,Good Luck
Unread 10-05-2010, 10:03 AM   #5
KUHawkhead
2008 KK Liberty
We had the same thing happen on our 08 this past week. Had a mechanic friend of mine check and reset the light. He told me that it would reset itself if it's nothing out of the ordinary within a week on its own.
KUHawkhead is offline   Reply With Quote Quick reply to this message
Unread 10-17-2011, 05:18 PM   #6
VMF
2008 KK Liberty
i just got this code today did yours dissapear after you changed the gas caps?
my jeep had the gas tank replaced under warranty and it was at the dealership for spider gear replacement over a week ago. since the evap canister is right in the proximity, i wonder if these things are related....
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline   Reply With Quote Quick reply to this message
Unread 10-18-2011, 07:37 AM   #7
Elt31987
Elt31987's Avatar
2008 KK Liberty
Yup hasnt happened since.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Unread 10-18-2011, 09:32 AM   #8
VMF
2008 KK Liberty
interesting... i wonder if my gas cap is bad or its just my lack and one of the hoses got a crack...
2004 UCF31. Black
Unread 10-20-2011, 10:57 AM   #9
VMF
2008 KK Liberty
well the light dissapeared 2 days after. i guess it was the cap, i removed it for inspection, no cracks, put it back in tight and it dissapeared. i was about to swap the gascapts between the liberty and the rubicon but decided to start n check first and it was gone! yey!
2004 UCF31. Black
Unread 10-20-2011, 12:13 PM   #10
tjkj2002
2002 KJ Liberty
Locking gas caps are known for leaking and don't do much good when a $5 tool is out there to easily remove them.
For $12 for a new gas cap it's just a good idea to change every year or at least every 2 years.
tjkj2002 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2011, 01:03 PM   #11
VMF
2008 KK Liberty
neither jeep has a locking one, just regular OEM caps that came with both cars. rubber seal seems to be fine i think i just didnt tighten it up enough after last refill.
2004 UCF31. Black
Unread 10-14-2014, 10:34 PM   #12
beherenow
2009 KK Liberty
so last friday the engine light came on... damm... just now i did the car key trick and the code back in the od came as P0456.... i still have the original 5 year gas cap... guess i"l hace to replace it and cross my fingers this gets resolved
beherenow is offline   Reply With Quote Quick reply to this message
Unread 10-15-2014, 05:05 AM   #13
josworth
2010 KK Liberty
Helpful tip..... visual inspection is pretty worthless with emissions regulated gas caps. Similar to a radiator cap, they contain a pressure valve that wears out. If your state has emissions testing, the test center will have a cap pressure tester. In Ohio, our e-check station will check your cap for free.
Some auto parts stores will test them as well.
Jeff
2010 Jeep Liberty Limited
josworth is offline   Reply With Quote Quick reply to this message
Unread 10-20-2014, 12:13 AM   #14
beherenow
2009 KK Liberty
changend my cap and the msg went away, yes!
