Changing Headlight Bulb on 2010 KK - JeepForum.com
post #1 of 10 Old 04-27-2010, 10:41 PM Thread Starter
pauld73
2010 KK Liberty
Does anyone know how to change the headlight bulb on a 2010 Liberty KK? I would appreciate any help from someone who has done this.
Thanks - Paul
pauld73 is offline
post #2 of 10 Old 04-28-2010, 04:58 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
You reach behind the housing and twist the bulb(dont remember which way) and it will then pull out and away from the housing. You then pull the red tab on the wire,push down and disconnect the bulb from the wire.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 10 Old 04-28-2010, 12:48 PM
diggerfreek
2008 KK Liberty
You might find it easier to remove the grill and the headlight unit to do the driver side. Also, make sure the rubber gasket comes off with the old bulb
diggerfreek is offline
post #4 of 10 Old 04-28-2010, 02:13 PM
geene519
2010 KK Liberty
nah, thats too much of a hassle...i didn't remove mine when i did my HIDs.
2010 Jeep Liberty Sport - Silver
Hankook Dynapro ATM tires, 14'' LED light bar
geene519 is offline
post #5 of 10 Old 04-28-2010, 02:24 PM
diggerfreek
2008 KK Liberty
I don't like to remove my battery... Plus on one of the radios, you can fry it if you don't pull a fuse...
post #6 of 10 Old 04-28-2010, 05:16 PM
geene519
2010 KK Liberty
didn't have to remove my battery either
geene519 is offline
post #7 of 10 Old 04-28-2010, 05:48 PM Thread Starter
pauld73
2010 KK Liberty
Changing Headlight on 2010 Liberty KK
Thanks for everybodys input. It sounds to me like the 2008 Liberty is different from the 2010 Liberty as far as the room available to get to the back of the headlight.
paul
pauld73 is offline
post #8 of 10 Old 04-28-2010, 10:32 PM
geene519
2010 KK Liberty
paul
i've owed both and on both i didn't have to remove the battery nor the front grill and my arms aren't that small either...lol
geene519 is offline
post #9 of 10 Old 04-28-2010, 10:57 PM
diggerfreek
2008 KK Liberty
I have thick arms
post #10 of 10 Old 04-29-2010, 06:46 PM Thread Starter
pauld73
2010 KK Liberty
I finally tried it myself on my 2010 KK. I was able to get my hand on both headlight sockets without touching the battery or the air cleaner scoop. It's tight and I didn't try turning the headlight connectors but since they are plastic screwed into plastic they shouldn't be that hard to twist off. I was also able to pull 3 plastic pins from the front wheel well to access the front turn signal and front side marker. The rear turn signal/brake lights are a piece of cake. Pull off the plastic light box, disconnect the electrical connector, and remove the backplate from the light box....change the bulb.
Now if I can only reach the oil filter I'll be set
pauld73 is offline
2010 Jeep Liberty- Worth buying? jkwik KK Liberty Forum 68 10-17-2010 10:56 AM
2010 Jeep Liberty with Sun Slider vs. 2010 4dr. Unlimited ?? britt22 KK Liberty Forum 20 10-08-2010 12:49 PM
Opinions on 2010 Liberty? planetlarson KK Liberty Forum 14 10-07-2010 05:28 PM
Where are the tow points ona 2010 Libby liredneck KK Liberty Forum 1 04-25-2010 07:09 PM
2010 Liberty Front Tow Hooks jamski KK Liberty Forum 2 03-15-2010 03:53 PM
