changing axle and tranfer case fluids - JeepForum.com
post #1 of 5 Old 04-27-2011, 08:41 PM Thread Starter
jeepster09
2009 KK Liberty
took my 09 KK Limited in for service, oil change, tire rotation, dealer says "it's time" to change axle and transfer case fluids, $300, and power steering should be flushed and changed, $85. " it is showing signs of being dirty".
KK has 27000 miles, it is driven mostly on pavement. I dont see anything in owners manual about changing these fluids, it mostly says to check them at certain intervals. what do you think, is it necessary?
jeepster09 is offline
post #2 of 5 Old 04-28-2011, 05:08 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Axles need to be done every 18K, Transfer case i believe is 60K
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 5 Old 04-28-2011, 08:48 AM
sloan74
You can do diff cases (axles) and xfer case yourself. Very easy on almost any truck. Diff cases you will need a gasket or you can use RTV, up to you. Xfer case you simply unbolt, drain, and fill up. My rover has single fill and drain bolts for the diff cases though, so it's super easy compared to the Jeeps. But it has other glitches that make up for it, aluminum engine block that does NOT like heat.....lol
I might pay them to do the power steering though, it can be a pain to bleed, and you definitely do not want air in the line. Might be worth 85 bucks.
Me personally, I would hold off on the axles and xfer case though, unless you took in some deep water/mud, and do the transmission fluid instead, possibly a coolant flush also.
I would rank tranny and coolant fluid (flushes and refill on both) more important than axle and xfer case gear oil for sure @ 30k miles. Esp if your on road mostly.
sloan74 is offline
post #4 of 5 Old 04-28-2011, 09:58 AM
tjkj2002
2002 KJ Liberty
The above is true for the axles since synthetic gear oil is used.
Just remember "Oil is cheap but a engine,trans,t-case,and diffs are not".The more often you service them the better in the long run for your wallet.
tjkj2002 is offline
post #5 of 5 Old 04-28-2011, 11:46 AM
SuperRliBerty
2008 KK Liberty
I did the trans and rear axle.... used castrol ATF+4 for the trans and mobil 75w90 for the rear axle ....
The Trans fluid change was somewhat messy and smelled terrible. The rear axle fluid was very easy to replace.
satan (dealer) wants $395 to replace the trans fluid and filter. $249 to do the rear axle.
PLEASE: take the old fluids to a recycling center, most auto store will take them.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
08 KK Liberty COMMAND-TRAC Transfer Case capacity mjcougler KK Liberty Forum 48 11-29-2016 04:54 PM
axle oil change, how much oil do i need? VMF KK Liberty Forum 10 12-15-2011 08:28 PM
Changing the fog light bulbs to amber but... mwegryn KK Liberty Forum 2 12-10-2010 11:29 AM
Changing my differentials oil enrico1 KK Liberty Forum 8 10-08-2010 12:54 PM
Changing Headlight Bulb on 2010 KK pauld73 KK Liberty Forum 9 04-29-2010 06:46 PM
