Change oil message - JeepForum.com
post #1 of 4 Old 12-16-2013, 10:23 AM Thread Starter
rangerr47
2012 KK Liberty
Change oil message
The last oil change I did myself, its been about 2500 miles 5w 20 Valvoline Synthetic if it matters, with a Napa gold filter.
It got cold here in Texas not long ago and after the jeep sat in my garage for 4 straight days of ice and sub freezing temps...the change oil message pops up when I start up. It does it every time I start up. I checked and the level is fine, looks ok as well, as in not black and nasty looking.
What I want to know is if this is because its been cold that its doing this? Was I suppose to reset something when I changed it last? I have never seen this message, I just always changed it when miles were up. So what makes it trip to tell you its time to change your oil? I just dont want it to cause problems.
rangerr47 is offline
post #2 of 4 Old 12-16-2013, 11:29 AM
nws2002
2011 KK Liberty
It's easy to reset. Just turn the key to on, not start just on, and push slowly on the gas pedal three times, then turn to off.
The engine computer calculates oil changes based on driving habits and other factors. It does not have a sensor that directly looks at the oil.
nws2002 is offline
post #3 of 4 Old 12-16-2013, 11:51 AM
Gageraid
2008 KK Liberty
I actually remembered for the first time to reset the message when I did my oil the other day.
Not sure how accurate it is, just don't be a dummy and change it when it's needed.
I was also a bit worried the first time I saw that message after changing my oil.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #4 of 4 Old 12-17-2013, 07:31 PM
Bmxer524
2011 KK Liberty
I find that it pops up whenever you change your oil and don't reset it. Not sure why, I also noticed some places don't reset it unless you have the message popping up(for those of you that don't change your own oil).
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
