Cabin air filter? - JeepForum.com
post #1 of 7 Old 04-11-2013, 09:37 PM Thread Starter
bigbentx
2012 KK Liberty
Cabin air filter?
Does anyone know if there is a cabin air filter in the 2012 KK? A while back, while driving cross country, my AC froze up and now every time the AC starts up, it has a horrible musty, mildewy, moldy smell. It's nasty for a while then goes away, but I'm hoping for a solution.
bigbentx is offline
post #2 of 7 Old 04-12-2013, 03:55 AM
scorpionarmor55
2010 KK Liberty
Right behind the glove. Once open squeeze the sides together and it folds out enough to access it.
scorpionarmor55 is offline
post #3 of 7 Old 04-12-2013, 07:52 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
2012 KK Filter - (Air Particulate) Removal
From the 2012 KK Factory Service Manual:
REMOVAL
WARNING: Disable the airbag system before attempting any steering wheel, steering column or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to follow these instructions may result in accidental airbag deployment and possible serious or fatal injury.
WARNING: Always make sure the A/C-heater system is turned off and that the ignition switch is in the OFF position prior to servicing the cabin air filter. Never place fingers or other objects into the filter opening of the HVAC housing. Failure to follow this warning may result in serious injury.
NOTE: LHD model shown in illustrations. RHD model similar.
NOTE: Illustration shown with instrument panel removed for clarity.
Remove the glove box bin.
Disengage the two retaining tabs (1) that secure the cabin air filter cover (2) to the passenger side of the HVAC housing (3) and remove the cover.
JeepCares is online now
post #4 of 7 Old 04-12-2013, 07:56 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
12 KK Filter - (Air Particulate) Installation
INSTALLATION
NOTE: The cabin air filter is labeled with an arrow to indicate air flow direction through the filter. Make sure to properly install the cabin air filter. Failure to properly install the filter will result in the need to replace the filter sooner than required by design.
See first illustration:
Install the cabin air filter (1) into the filter opening in the HVAC housing (2). Insert the cabin air filter directly into the housing with the arrow on the filter pointing to the floor.
See second illustration:
Position the cabin air filter cover (2) to the HVAC housing (3) and engage the two retaining tabs (1) that secure the cover to the housing. Make sure the retaining tabs are fully engaged.
Install the glove box bin.
post #5 of 7 Old 04-14-2013, 07:03 AM Thread Starter
bigbentx
2012 KK Liberty
Thanks, found it this morning. I plan on buying one soon and they run about 25 dollars.
bigbentx is offline
post #6 of 7 Old 04-17-2013, 07:19 PM
Ted15
2010 KK Liberty
eBay 18.00
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #7 of 7 Old 04-17-2013, 09:39 PM
Dave_B
2008 KK Liberty
$6.18- $22.79 at ROCK AUTO
Lovin' my CARBON FOOT PRINT!
Dave_B is offline
