Burning smell when 4X4 used - JeepForum.com
post #1 of 25 Old 02-12-2014, 01:24 PM Thread Starter
mrbeal
2011 JK Wrangler
I noticed in the last couple of snow storms that there is a burning smell in the cabin when using 4X4 with front wheel slip. Almost smells like an oil burning smell but not quite... could be transmission maybe? Any ideas?
mrbeal is offline
post #2 of 25 Old 02-12-2014, 01:50 PM
Gageraid
2008 KK Liberty
First thing that came to mind was maybe you're smelling your tires?
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #3 of 25 Old 02-12-2014, 02:00 PM Thread Starter
mrbeal
2011 JK Wrangler
Nope... not a burning rubber smell and the tires only lose grip on the show and ice I'm playing in.
mrbeal is offline
post #4 of 25 Old 02-12-2014, 02:28 PM
RENE65
2008 KK Liberty
Most of the time,a burning smell comes from an oïl leak,that would be my first thing to check.
RENE65 is offline
post #5 of 25 Old 02-12-2014, 03:43 PM
Gageraid
2008 KK Liberty
If this is the case, check the oil filter first. It's up there somewhere.
OME lift
Gageraid is offline
post #6 of 25 Old 02-12-2014, 05:30 PM
rescue575
2011 KK Liberty
I was getting that smell too (in general-not only during 4x4). Just happened after this cold spell. I assumed it was the filter as well. That and te fact that I was dinging little puddles of oil in the white snow. Got the oil changed and mech even told me the filters are crap and the seals break down. Especially with the fluctuation of temps we have been having here in NY
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #7 of 25 Old 02-13-2014, 11:46 AM Thread Starter
mrbeal
2011 JK Wrangler
^^^ That could be part of it, I still have about 1200 miles before an oil change BUT the temps here have been wildly fluctuating 50's down to 2 over the last month and everywhere in between. Strange that it's only when I use 4WD and have fron wheel slip though... something to look at at least.
mrbeal is offline
post #8 of 25 Old 02-13-2014, 01:54 PM
Sagerist
Sagerist's Avatar
I get a burning smell after i drive on winter days. But luckily its just the magnesium chloride they use to de-ice the roads that gets caked on the muffler with all of the other road grime...
There was a point my differentials were getting real hot and i would get a warning from the jeep about 4x4 components overheating. A flush of the fluids took care of that issue tho.
Colorado Jeep Club Member #286
89 YJ 2.5L
OME 36R's, Bilstein 5100's, Bserk 5/8" shackles, 33x10.5 BFG's on 15x8
09 KK Sport 4X4
235/75/16 GY Slnt Armor
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
post #9 of 25 Old 02-13-2014, 05:23 PM
LKWJEEPER
2009 KK Liberty
Just went out today and used 4wd in Wal-Mart's parking lot because it was a frozen mess! Got home and had a slight smell near the front grill. I've come to the conclusion it's something I hit in the snow or its because I never use the 4wd.
Sent from AutoGuide.com Free App
LKWJEEPER is offline
post #10 of 25 Old 02-20-2014, 07:03 AM Thread Starter
mrbeal
2011 JK Wrangler
After driving a little more and using 4WD again in even more snow I have come to the conclusion that it is indeed a burning oil snow. It is constant now, like is started slow and just happened to coincide with 4WD use, and is now a larger leak that is noticeable all the time. Hopefully Saturday I can get enough of the Jeep into the garage and crawl under and look at the oil filter. Thanks to all for the help identifying the culprit.
mrbeal is offline
post #11 of 25 Old 02-20-2014, 07:09 AM
Gageraid
2008 KK Liberty
Definitely check the oil filter, mine as well do an oil change if you're close to due for one. Check the front diff, too. Maybe use 4x4 somewhere enough to get the smell and pull over somewhere safe and open the hood to see if it's coming from there.
Good luck and keep us posted.
OME lift
Gageraid is offline
post #12 of 25 Old 02-21-2014, 01:16 PM
oct1196
Could it be your traction control/stability control? I am new to being a Jeep owner, bought a 2012 Liberty Sport, but thought these used the brakes to maintain control. if you are driving in icy conditions these may just be getting hot from abnormally high use? Just a thought.
oct1196 is offline
post #13 of 25 Old 02-21-2014, 01:27 PM Thread Starter
mrbeal
2011 JK Wrangler
I'm gonna say no... I know the smell of hot brakes and it's not that. You are correct though, when the wheels spin the brakes take over and help you to get traction.
mrbeal is offline
post #14 of 25 Old 02-24-2014, 11:27 AM Thread Starter
mrbeal
2011 JK Wrangler
OK, so Saturday I did my best to slide under the Lib and look for the oil filter... nope, couldn't find it. I even Googled it to make sure I was looking in the right place and still couldn't find it. I wasn't able to get all the way under (especially to the sides of center) so I'll have to either put it up on jack stands to be able to get underneath (like I really have time for this) or just deal with it until the next oil change and check the oil level frequently. I had a WAY easier time sliding under the front of my Outback than the Lib, just sayin'.
mrbeal is offline
post #15 of 25 Old 02-24-2014, 12:07 PM
Sagerist
Sagerist's Avatar
Yea, it's tight under there, especially if you have skid plates getting to the oil filter. I do like the fact that they did engineer an oil duct to capture the oil and run it away from where the filter attaches so it doesn't bleed oil onto all of the components right underneath the filter. of course, i realized that was there and what it was for AFTER i pulled the filter and frantically tired to move the oil pan to catch the oil! haha
This should help. Skip to section 5 where it actually talks about the filter.
http://www.carcarekiosk.com/video/20...and_oil_filter
89 YJ 2.5L
09 KK Sport 4X4
CB 2' Firestik
Fire/EMS Radio
Sagerist is offline
