burning oil smell - JeepForum.com
post #1 of 3 Old 05-09-2013, 09:21 PM Thread Starter
donniesoup
1980 FSJ Cherokee
burning oil smell
I have a 2011 with 60k on it. After it warms up after starting it will smell like burnt oil out of the vents. Why is this and how do I stop it. Thank you.
2011 liberty 70th anniversary
1980 cherokee
Do what you should now so you can do what you want too later!
donniesoup is offline
post #2 of 3 Old 05-10-2013, 09:41 AM
mrbeal
2011 JK Wrangler
First, are you sure it's oil you smell? It is possible you have an oil leak BUT I've been fooled by the smell of axle grease burning -check your CV boots for tears/grease, could very easily be that.
mrbeal is offline
post #3 of 3 Old 05-10-2013, 11:20 AM
rescue575
2011 KK Liberty
Also, who did your last oil change (if this has only occurred recently. There have been posts on here and i have experienced it first hand. It is not that easy to reach the oil filter so there have been issues of the filter not being tightened properly causing a leak.
I went to a jiffy lube (needed it done quick). They told me my main seals were leaking. When i brought to dealer, turned out to be the filter. Oil did splatter all over the place so now periodically i get that oil smell when i run the motor.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
