-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   Bull bar, roof rack and lights installed (http://www.jeepforum.com/forum/f292/bull-bar-roof-rack-lights-installed-1344518/)
jsburton84 03-17-2012 09:32 PM
This weekend i finally got the chance to make the drive back to ohio to install my long awaited Christmas gifts for the KK. I got the westin bull bar with fog lights, defender roof rack and 4x hella 500 off road lights. All of the lights are hooked up to ARB switches with custom covers from sierra expeditionshttp://www.sierraexpeditions.com/ind...uct_list&c=358
After reading some write-ups, decided to install the lights before mounting the pieces to the vehicle:
http://img.photobucket.com/albums/v1...4/P3161551.jpg
http://img.photobucket.com/albums/v1...4/P3161554.jpg
http://img.photobucket.com/albums/v1...4/P3161553.jpg
http://img.photobucket.com/albums/v1...4/P3161559.jpg
I discovered that the roof of the KK is actually tapered a bit to the rear when doing the test fit on the roof rack. As a result, it was necessary to modify the rear mounting points with a cut-off wheel. the parts that got cut out are marked in pencil.
http://img.photobucket.com/albums/v1...4/P3161558.jpg
Here it is with everything bolted up:
http://img.photobucket.com/albums/v1...4/P3161560.jpg
http://img.photobucket.com/albums/v1...4/P3161561.jpg
After much debating, decided to mount the switches on the bezel and in the console respectively. These locations worked out great since they had enough room to fit the back of the switch, a good grounding point, and a 12v source to splice into near by (the cigarette lighter/ accessory outlet)
http://img.photobucket.com/albums/v1...4/P3161563.jpg
http://img.photobucket.com/albums/v1...4/P3161564.jpg
http://img.photobucket.com/albums/v1...4/P3171576.jpg
Many hours later, all the wiring was complete and nicely secured :2thumbsup::
http://img.photobucket.com/albums/v1...4/P3171569.jpg
http://img.photobucket.com/albums/v1...4/P3171570.jpg
silver08kk 03-17-2012 11:19 PM
AWESOME!!! Looks fantastic!!!!
GermanyBert 03-18-2012 01:20 AM
That look really great!
Bmxer524 03-18-2012 02:32 AM
Looks good! Now I have to hurry and wire my lights :(
jonrjen 03-18-2012 04:53 AM
Looks fantastic. Any chance of a photo showing how you ran the wires from the interior to the lights on the roof? Any night photos to share?
jonrjen 03-18-2012 04:54 AM
Also, what tire size, lift size and manufacture are you running?
Jeepin11 03-18-2012 05:29 AM
Looks good man. What do you think of the bull bar? How sturdy do you feel it is? How does it mount up?
jsburton84 03-18-2012 05:47 AM
The Bull Bar is pretty solid 2" pipe mounted to 1/4" steel brackets with 1/2" Bolts. The brackets are actually a little beefier than the Mopar tow hooks and mount to the same spot so you will have to remove them to put the bar on. It feels sturdy enough for my purposes which was to have a place to mount fog lights. The bar came with free lights that you mail-in for and the whole thing was cheaper than buying the replacement housings with factory fogs or the $500 bull bar from mopar that connects with plastic pop-rivets! I might eventually get the tow hook welded directly to the frame somewhere else.
Jeepin11 03-18-2012 06:04 AM
That's what I don't want. I am part of an off road club and one of the requirements is front and rear tow points. I would have to figure out a way to get the tow hook back.
eoerikson3 03-18-2012 06:29 AM
It looks good. Were you able to re-install the front tow hooks?
jsburton84 03-18-2012 06:37 AM
No, the mounting brackets for the bar go in the same spot as the factory tow hooks. You could probably put some after market hooks to the side or directly on the bottom of the frame about 10 inches behind the front bumper.
musclezmarinara 03-18-2012 09:10 AM
id love to do the same! mine would have a quick disconnect for the rack basket lights :)
where did you wiring everything down into the cab?
i think i may tackle this!
Lehman26 03-18-2012 09:24 AM
Looks really good...i really like how well you mounted the switches
jsburton84 03-18-2012 06:42 PM
The lights on the roof are all grounded up top, and the rack is grounded to the body with another wire. There are actually only two wires that go from the roof to under the hood, and three that go from under the hood to inside the cab through that rubber grommet in the corner of the engine bay near the steering wheel. The rest is all either inside the console or under the hood. I will take some better pics tomorrow and post them with more detailed explanation.
jsburton84 03-18-2012 06:47 PM
Thanks,
I picked the mounting locations, but I owe the credit to a professional electrician (step dad) to make sure it was done right.
The time now is 09:47 PM.
