Breaking In Liberty - JeepForum.com
post #1 of 10 Old 05-23-2010, 05:17 AM Thread Starter
oldbanker
Breaking In Liberty
I just bought a new 2010 Liberty Limited and could not find any breakin instructions in the owners manual. The salesman also was no help. From owning other new cars, usually there are defined instructions on speed restrictions, etc. for first 500-1000 miles. Any help would be appreciated.
oldbanker
oldbanker is offline
post #2 of 10 Old 05-23-2010, 05:39 AM
tjkj2002
2002 KJ Liberty
Well if you want to do it right keep the speed down(55mph max) for the 1st 500 miles,no towing or wheeling.Always allow the engine to reach normal operating temps before shutting off,very important as it "heat cycles" the internal parts.Keep the rpm's low,so no WOT(wide open throttle) starts and passes.
And the biggest thing is to change the oil/filter at 500miles.
Your also breaking in the diff gears,trans,and t-case(if 4wd) at the same time also and heat cycling the diff gears is a must for long life.
tjkj2002 is offline
post #3 of 10 Old 05-23-2010, 05:19 PM
Nitz240d
2010 KK Liberty
It's funny, I was wondering the same thing myself because there is no mention in the owners manual and my salesman didn't say anything about it either.
As you mentioned, I have always been told low rpm's, no WOT and 500-750 mile oil change.
-Erik
2010 Jeep Liberty Sport 4x4
Dark Charcoal Pearl / Dark Slate Gray
Command-Trac II
Stock...for now
Nitz240d is offline
post #4 of 10 Old 05-23-2010, 06:34 PM
daggo66
2009 JK Wrangler
I believe the 2010's came with an "owner's guide" and the full manual should be on a DVD. If not you can go to the Jeep website and download it. Here is the engine break-in information from the '08 manual. It should be the same.
A long break-in period is not required for the engine in
your new vehicle.
Drive moderately during the first 300 miles (500 km).
After the initial 60 miles (100 km), speeds up to 50 or 55
mph (80 or 90 km/h) are desirable.
While cruising, brief full-throttle acceleration, within the
limits of local traffic laws, contributes to a good break-in.
Wide-open throttle acceleration in low gear can be detrimental
and should be avoided.
The engine oil installed in the engine at the factory is a
high quality energy conserving type lubricant. Oil
changes should be consistent with anticipated climate
conditions under which vehicle operations will occur.
The recommended viscosity and quality grades are
shown in Section 7 of this manual. NON-DETERGENT
OR STRAIGHT MINERAL OILS MUST NEVER BE
USED.
A new engine may consume some oil during its first few
thousand miles (kilometers) of operation. This should be
considered as a normal part of the break-in and not
interpreted as an indication of difficulty.
Tom
daggo66 is offline
post #5 of 10 Old 05-23-2010, 07:15 PM
Nitz240d
2010 KK Liberty
your new vehicle.
USED.
So they're NOT recommending an oil change before 3,000 miles...interesting.
-Erik
Command-Trac II
Stock...for now
Nitz240d is offline
post #6 of 10 Old 05-23-2010, 08:53 PM
tjkj2002
2002 KJ Liberty
-Erik
Ask any pro engine builder about when your 1st oil change should be,most will say 500miles and some will say as soon as 100miles.
tjkj2002 is offline
post #7 of 10 Old 05-23-2010, 10:59 PM
Nitz240d
2010 KK Liberty
That's what I was always told and most manufacturers recommend it - that's why I'm surprised Jeep doesn't.
-Erik
Command-Trac II
Stock...for now
Nitz240d is offline
post #8 of 10 Old 05-23-2010, 11:29 PM
geene519
2010 KK Liberty
with modern precision machining, a strick breakin procedure really isn't needed anymore. typically some moderate driving and not keeping a steady RPM for the first 500 miles is more than enough.
2010 Jeep Liberty Sport - Silver
Hankook Dynapro ATM tires, 14'' LED light bar
geene519 is offline
post #9 of 10 Old 05-23-2010, 11:37 PM
Nitz240d
2010 KK Liberty
For $40 or $50 for oil and a filter I think I'll stay on the safe side and change at 500.
-E
Command-Trac II
Stock...for now
Nitz240d is offline
post #10 of 10 Old 06-08-2010, 06:14 PM
GearGuy10
-Erik
If the 2010 manual is similar to the 2009, the oil changes are every 6,000 miles. Personally, I couldn't do it. I changed mine at 1k, 2k, 3k, 6k and 12k. Now I'll go every 6k with Mobil 1.
HIS: 1998 Cherokee Sport Chili Pepper Red-SOLD
DrawTite front hitch
HERS: 2009 Liberty Sport Light Graystone Pearl
100% Stock
GearGuy10 is offline
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 08:28 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 01:12 PM
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 01:35 PM
Cleaning your Liberty Nitz240d KK Liberty Forum 7 06-10-2010 02:32 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
