Brake Service Indicator?? - Page 2 - JeepForum.com
post #16 of 23 Old 08-04-2010, 07:27 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Reason being is the KK is RWD and when the tires slip ESP applies the brakes to the slipping tires (the rear).
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #17 of 23 Old 08-04-2010, 07:44 AM
louder1
2008 KK Liberty
makes sense, thanks for the info...
louder1 is offline
post #18 of 23 Old 06-01-2011, 11:17 AM
olblueyez
Hello everyone,
Did we ever come to general consensus as to replacing/repairing the rotors along with the pads? Our 08 KK has 27,000 miles on it and I am sure its ready for pads.
olblueyez is offline
post #19 of 23 Old 06-01-2011, 12:40 PM
louder1
2008 KK Liberty
Well,
Our 08 has 65K on it, I've already replaced the pads all around once but I did not turn the rotors. I need to do them again now and I'll probably replace the rotors as well. I've heard good things about the NAPA premiums so I'll go with that all around.
The rears definitely need to be replaced by 30K but the fronts were ok. I replaced all since I was in there at the time, the rotors should have been turned but there isn't much meat on them so I left them figuring I would need to replace soon. They've held in there but I'm overdue at this point.
louder1 is offline
post #20 of 23 Old 06-02-2011, 09:26 AM
olblueyez
I notice that since the pads have worn that the jeep has a wobble with heavy braking. I can feel it in the steering wheel. Will the new pads solve that or would turning or replacing the rotors be necessary to eliminate that? I don't want to put new pads on it if the old rotors will cause premature and or uneven wear.
I also notice pads and rotors from Mopar and Napa are not much different in price.
BTW: Great website,,!!!
post #21 of 23 Old 06-02-2011, 09:53 AM
louder1
2008 KK Liberty
The wobble is probably your front brakes and yes they would either need to be turned or replaced the rotors, attached is the min. thickness.
I'm going with the Napa Premiums hoping to get better than the stock performed, maybe with the Napa combination of premium pads & rotors they will last longer than the stock did especially the rears.
Good Luck.
louder1 is offline
post #22 of 23 Old 06-02-2011, 10:49 AM
olblueyez
Cool, that makes up my mind for me. New rotors and pads and Napa. I believe Napa was the cheaper of the two.
post #23 of 23 Old 07-01-2013, 03:56 PM
mjcougler
2015 WK
Yes, but I'm not sure why. I posted a thread when I changed-out my rears. My biggest problem was with rust. I'm in Roc NY and we have to deal with road salt. Now I'm looking for front brake information. I still have lots of pad, but they bound up on my wife once. As I take them apart, I'm finding tight tolerances and when there is rust, the swelling of the metal causes binding. My problem I'm trying to resolve now is: I popped off the old stainless clips, and I did not notice which way they came off.
I'll post later the results of my front brake job as we can all learn from each other.
Mike Cougler
15 Jeep GCL; 11 Jeep CL; 67 Jeep M725 Ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A
mjcougler is offline
Parking Brake adjustment '08 Liberty 08liberty KK Liberty Forum 23 07-02-2017 05:32 PM
30K Service estimates boulderado KK Liberty Forum 16 01-29-2012 08:32 AM
Chrysler Service Contracts? GearGuy10 KK Liberty Forum 7 03-19-2010 06:12 AM
Removing Brake Caliper MikeFinn KK Liberty Forum 2 02-22-2010 12:44 PM
Chrysler Recalls for Possible Brake Failure mike79 KK Liberty Forum 0 01-18-2010 11:01 AM
