Since I more then likely will be replacing the front calipers on my wife's 08 liberty, I might as well change out the rubber lines since I will be halfway there.
Does anyone know of any companies that make the braided brake lines for these?
i may be completely off here, so please dont go by just what i said, but brake lines are brake lines are they not, minus a few differences in lengths or thickness, but couldnt you buy regular braided lines for something and make them fit, that is assuming that there's not too much difference in the lines themselves? i would see if i could find some for maby a xj cherokee or something where you could get them in a bundle and see if they would work. like i said im a novice i know nothing of the differences in lines or how unique they are to each model, so just my 2 cents. hope this helps. good luck.
Pretty sure you can use what ever you want. You just need to know the length, the diameter, and the thread sizes you need. Here is a link a universal kit. http://www.jegs.com/p/JEGS-Performa...eel-Universal-Brake-Line-Kit/2826067/10002/-1 You need to weld these, but I'm sure you can take them to an welder once you measured everything.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
