Beach advice/stories? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Beach advice/stories?
Win a $250 Gift Card to ZoneOffroad.com - 4th of July FaceRuffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-25-2014, 09:10 PM   #1
jrenee78
2010 KK Liberty
Hey, everyone!
I'm super new to the forum, just got my Liberty a month ago but my husband's had three Wranglers in the eight years I've known him so I'm fairly familiar with the Jeep family. (A little bummed that I can't get a Jeep wave but I'll live.)
We are heading down to the Outer Banks on Saturday for a week, and I just wondered if anyone had any advice or tips or even just fun stories of taking their Liberty on the beach?
jrenee78 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 09:13 PM   #2
Gageraid
2008 KK Liberty
You can remove the front air dam for a little more clearance on the sand.
If member Poncherello chimes in, he's been on the beach quite often with his and I'm sure he'd have some advice because I know he's had some issues plus great times on the beach.
You'll probably need to air down the tires.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 10:59 PM   #3
AtTheHelm
Definitely air down and keep momentum...
I don't know if there are any sand hills or dunes at the beach you're going to, but if you come to a hill don't stop unless you can back down. The key is momentum in sand. I used to take my 2wd prerunner Tacoma to Pismo beach that has big dunes. The very first thing I did was get stuck 20 ft into the soft sand. After getting pulled out I aired down to 15 psi, kept on the throttle and couldn't keep a sh*t eating grin off my ugly mug because it was so much fun.
AtTheHelm is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 06:18 AM   #4
Bmxer524
2011 KK Liberty
As said the biggest thing is to air down. I run about 15-18psi on the sand. Also, keep moving. If you do stop and you start to spin the wheels and dig in then let off the gas. Generally if I start to dig I try to reverse out. If that doesn't work, I go to 4Low and drive out. If that doesn't work try reverse again...and if that doesn't work look for a friendly person to give you a tug lol
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 07:02 AM   #5
Babaki
2012 KK Liberty
carry some things with you. bottle jack, small shovel, a piece of wood that you can either use for the jack or get out of a hole, a chain or tow strap.
Babaki is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 10:31 AM   #6
DrD28
Air down is a must in soft sand 10-15 psi. Shovel a good piece of wood tow ropes and a fire extinguisher
DrD28 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 11:48 AM   #7
jrenee78
2010 KK Liberty
Thanks for the responses! I know to definitely air down. We have a shovel, wood, ropes, etc in case she gets stuck. We've driven this beach before, in the Wrangler, and it's really nice, flat beach. The only real obstacle is the ruts where everyone else has driven but it's manageable. I think I just needed some reassurance that the Liberty can manage sand. This is the first time I'll really get to see what she can handle!
Unread 08-26-2014, 12:03 PM   #8
Bmxer524
2011 KK Liberty
Straddle the ruts. Depending on how deep they get you'll drag a bit. Before I was lifted I used to drag the belly on some deep ruts, and my air dam(as said, it's removable, quite easily too) would take a beating. I'd come home with sand stuck between the air dam and bumper.
Unread 08-26-2014, 05:30 PM   #9
knightenforcer
2011 KK Liberty
+1 on This, I ran 16-15 psi on sand and have been using the staun II tire deflators to make quick air downs. Also, a good air compressor is a must
Not sure what 4x4 you have, I have the command trac and I just put it on 4 High and ESP off.
Reversing is a good option if you get stuck, as the sand behind you is already compacted.
Here's a thread I started on the other forum, with a few pics of KK's at the beach. (IMHO, it is more than capable on sand)
http://www.lostjeeps.com/forum/phpBB...hp?f=6&t=78992
2011 Jeep KK Liberty, Blackberry, ATH bumper, JBA Lift, Bilsteins, 245/75/16, Dynomax, K&N etc
knightenforcer is offline   Reply With Quote Quick reply to this message
Unread 08-26-2014, 08:08 PM   #10
Poncherello
2010 KK Liberty
All good advice, written above there is a saying the day you don't air down is the day you won't forget lol.
List:
Air compressor
Tire gauge
Recovery straps
Recovery hooks on your vehicle front and back
Shovel
Solid prices of wood
Fire extinguisher
Map of the beach
Honey bucket
Bottled water/toilet paper
I always kept the Lib in 4hi and air downed to half way especially when sand was real dry & soft. Problem with Lib with stock suspension as Bmxer said sometimes the belly drags on the sand. When your done just rinse the under carriage.
Have fun
When you get knee-deep in a situation, floor it.
Poncherello is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 07:03 AM   #11
_benjammin
2012 KK Liberty
As mentioned, air down to 12-14. Use 4Low unless you are going faster then 20-25mph.
After your trip plan some time to crawl around with a hose spraying everything underneath. Hit every hole in the frame and gas tank skid with water and pounds of will wash out.
_benjammin is online now   Reply With Quote Quick reply to this message
Unread 08-27-2014, 07:04 AM   #12
_benjammin
2012 KK Liberty
And I have fun a few times a week driving out on the North End of Carolina Beach (Freeman Park).
Unread 08-27-2014, 09:01 AM   #13
ArcticDude88
2012 KK Liberty
What is the deal for 4lo and sand? I have gotten mixed answers from google and other forums if 4lo is useful for sand or not
ArcticDude88 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 09:25 AM   #14
_benjammin
2012 KK Liberty
Soft sand and low speed, use 4 low. Hard sand and high (> ~20mph) use 4hi.
Unread 08-27-2014, 09:31 AM   #15
_benjammin
2012 KK Liberty
4lo disables ESP (somewhat). ESP is not beneficial in soft sand.
