Battery terminal quick release mod - JeepForum.com
post #1 of 9 Old 10-27-2010, 02:27 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I replaced my battery and while installing the 10mm nut, it fell. I heard it fell and hit the ground and for the life of me I could not find it! spent about 15 minutes looking for it. I finally give up and went and buy a $1.25 wing nut with a looking washer attached to it.
Each time I change my oil I reset the ECU, by ALWAYS removing the NEG-(black)terminal first, then the POS+(red) terminal. takes me 10 seconds to unsrew the wing nut and remove the cable. Then ALWAYS INSTALL THE POS+ (RED)TERMINAL FIRST AND THE NEG - (BLACK) TERMINAL LAST10271018.jpg
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #2 of 9 Old 10-27-2010, 03:15 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
The negative should always be removed before the positive and when you put it back together its the opposite, positive then negative.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 9 Old 10-27-2010, 03:48 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Originally Posted by elt31987 View Post
the negative should always be removed before the positive and when you put it back together its the opposite, positive then negative.
very true!
2008 Sport Liberty
post #4 of 9 Old 12-20-2010, 09:32 AM
ChrisPearce8841
2008 KK Liberty
I work at a store called Battery Source and we see a lot of bad stuff. One thing I have to highly suggest is to NOT USE WING NUTS. They come loose easier and will start to vibrate and arc. This will cause them to start welding and then melt your terminal . I see this at least once a month.
ChrisPearce8841 is offline
post #5 of 9 Old 12-20-2010, 01:11 PM Thread Starter
SuperRliBerty
2008 KK Liberty
I installed the locking wingnut in the summer of 2009 and I can honestly say It has never arched, melted or welded against the terminal
I wanted to get these terminals ($5 ea.), but the red cover protects it nicely.
2008 Sport Liberty
post #6 of 9 Old 12-20-2010, 01:53 PM
joelwg
2005 WJ
QUICK RELEASE BATTERY CLAMPS TERMINALS QR on eBay (end time 27-Dec-10 03:57:45 GMT)
I have something similair on another car I own and have never had a problem, they are fast, easy, and you dont have to mess around with nuts bolts or anything else.
joelwg is offline
post #7 of 9 Old 12-20-2010, 02:49 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Hello Joel, whats the weather like there in good ole jolly england?
The idea was to install a quick release and never have to mess with the bolts
2008 Sport Liberty
post #8 of 9 Old 12-20-2010, 03:12 PM
joelwg
2005 WJ
Very cold with snow at the moment (just a dusting in our area though), looks like were in for a white christmas
joelwg is offline
post #9 of 9 Old 12-20-2010, 03:19 PM Thread Starter
SuperRliBerty
2008 KK Liberty
Then your WJ should come in handy
2008 Sport Liberty
Latest press release Gramps KK Liberty Forum 3 09-15-2010 09:20 AM
