Battery Keeps Dying - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Battery Keeps Dying
RuffStuff's LABOR DAY SALE!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-31-2015, 07:17 AM   #1
willifordg
Battery Keeps Dying
So I'm having a problem with the battery dying. I've had the battery checked and I've been told that the battery is fine. The suspicious thing is that the KK acts like I'm pressing the lock button on my key fob, even when I'm not. The horn honks and the door lock motors do their thing. Something in the Jeep is not shutting off, I suspect the TPIM may be bad, but just had it replaced by the dealership about 2 years ago.
Any thoughts?
willifordg is offline   Reply With Quote Quick reply to this message
Unread 09-01-2015, 08:00 AM   #2
x99j
Bad or failing batteries can cause the symptoms described. I would get it tested at another outfit to be sure! Maybe when voltage gets low the locks and horn go haywire?
Sounds like it could be the power module?
I would also suspect the radio/cd player. I have heard mine making noise 5 minutes after vehicle has been turned off. But the real way to track it down is measuring amp draw at the battery while you pull fuses.
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline   Reply With Quote Quick reply to this message
Unread Today, 03:06 PM   #3
JeepCares
FCA Customer Care
JeepCares's Avatar
Any thoughts?
Hey willifordg,
What model year and type of engine do you have? This information will help me look further into your concerns.
Ryan
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
