Banging Noise in Rear of KK - JeepForum.com
post #1 of 16 Old 11-24-2009, 01:32 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
So i have this Banging noise in the read end of my KK. This ONLY happens when going off roading and sometimes over speed bumps at speeds over say 10mph. The noise is kind of like a thud, it doesnt sound like metal on metal or anything. It happens when going over rocks and holes in the ground. I took a quick look and everything seems tight. I did notice on my Shock Boot if i squeezed the bottom of the boot that some water came out which i got it all out. I dont know if this would cause it. Any ideas?
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #2 of 16 Old 11-24-2009, 01:58 PM
mike79
Spare tire's loose?
mike79 is offline
post #3 of 16 Old 11-24-2009, 07:21 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Checked, Sorry i didnt mention
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #4 of 16 Old 11-24-2009, 08:15 PM
LibertyTC
2004 KJ Liberty
Wonder if the rear coils are impacting the bump stops.
Time to upgrade the shocks and coils etc..then...stockers are kinda weak.
LibertyTC is offline
post #5 of 16 Old 11-24-2009, 08:24 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
well im running a daystar spacer with stock coils and SkyJacker 2.5" Shocks. The spacers have been in for about 5K miles. Im thinking maybe the coil and spacer seperate and thats causing the bump noise
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #6 of 16 Old 11-24-2009, 11:10 PM
95BadBoy
Elt
You didn't by chance misplace your bowling ball or something else in the back of your KK did you?
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #7 of 16 Old 11-25-2009, 08:39 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
lol no never was really good at bowling anyway
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #8 of 16 Old 11-25-2009, 10:28 AM
mike79
I had to track down a similar noise on my other vehicle (2003 Mustang Cobra) and I had a buddy stand outside the car while I rolled over the speed bump- we were able to isolate the sound that way. Maybe give that a try?
mike79 is offline
post #9 of 16 Old 11-25-2009, 11:48 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
ya it happens 100% of the time when offroading even at low speeds and not as often when going over speed bumps. I was going to try this but being in NY you know its gettn pretty cold here in MA and the snow is on the way
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #10 of 16 Old 11-26-2009, 06:01 AM
Roadster71
Loose shocks? I had a similer thing with my Dodge pu and a turn on the shock mount bolt was all it took.
Roadster71 is offline
post #11 of 16 Old 11-26-2009, 08:03 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ya ill retorque em and see what happens. Thanks
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #12 of 16 Old 11-27-2009, 06:51 AM
xjokee
fahhgetaboutit......
Take the body outa the back.
Mike
~ When in doubt........Throttle out! ~
xjokee is offline
post #13 of 16 Old 11-27-2009, 07:09 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
It fit in the water proof tray thankfully
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #14 of 16 Old 12-06-2009, 09:33 AM
rugsucka
Maybe Tiger Woods is hiding in the back with the local IHop waitress.
rugsucka is offline
post #15 of 16 Old 12-06-2009, 11:29 AM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Problem Solved. The bushing on the top of the shocks isnt wide enough for the bracket it goes into. Picked up 4 washers from the hardware store and put 2 on the inside of each bracket with the shock so there was no play and problem solved.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
First Time in th Snow- Griding Noise??? mike79 KK Liberty Forum 13 12-22-2009 11:57 AM
