Backspacing - JeepForum.com
post #1 of 3 Old 02-19-2017, 06:21 PM Thread Starter
kyle247
Backspacing
OK I know there is tons of posts on here about which backspacing to use, but i want to make sure i get this right. I have a 2012 Jet. Im upgrading my rims to 16x8 and 30.5 tires.
I am using fuel revolver rims part number D52516802645 and BF Goodrich 245/75R16 tires. I am also installing the OME 1.5" lift hoping to get about 2.5" of lift.
So my question is, the rims have a back spacing of 4.5in and an offset of +1. Will that work? Id like my tires to just barely stick out of my wheel wells.
kyle247 is offline
post #2 of 3 Old 02-20-2017, 11:01 AM
Bmxer524
2011 KK Liberty
If you're going 8" wide rims I recommend a 265/70-16. It won't stretch the sidewalls as much, but you may have some rubbing on the pinchweld (strong possibility of that with the 245/75-16s just because of the rim specs).
Anyways, 16x8 with 4.5" of backspacing will hang out the flares by about 1/4" or so.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #3 of 3 Old 02-21-2017, 08:40 AM
tommudd
2004 KJ Liberty
8 inch wide wheel needs 5 inches of backspacing
7 inches wide you can do 4 inches of backspacing
both of course on a lifted Liberty
yes 1/2 inch makes a difference in turning radius
and like mentioned 265-70-16s ( same height as 245-75-16s) work better on a 8 inch wide wheel
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
