axle oil change, how much oil do i need? - JeepForum.com
post #1 of 11 Old 09-03-2010, 10:32 AM Thread Starter
VMF
2008 KK Liberty
im about to go to the store to get it
please advice on the amounts
and what kind of sealant would u recommend?
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #2 of 11 Old 09-03-2010, 10:34 AM Thread Starter
VMF
2008 KK Liberty
Valvoline/1 qt. 80W-90 Durablend synthetic gear oil (280) | Gear Oil | AutoZone.com
hows this one for the front? i never used volvoline b4
2004 UCF31. Black
VMF is offline
post #3 of 11 Old 09-03-2010, 10:36 AM Thread Starter
VMF
2008 KK Liberty
Mobil/1 qt. (946.353 ml.) SAE 75W-140 light truck and SUV formula synthetic gear lubricant (98FS32) | Lubricant/Grease | AutoZone.com
and thisone for the rear
2004 UCF31. Black
VMF is offline
post #4 of 11 Old 09-03-2010, 06:44 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
I use Mobil 1 75 140 in both axles
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 11 Old 09-03-2010, 07:32 PM Thread Starter
VMF
2008 KK Liberty
thank you for your replyhow much do i need for each axle?
2004 UCF31. Black
VMF is offline
post #6 of 11 Old 09-03-2010, 08:26 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Between both youll need about 4 Quarts i think, the front uses a little less than 2 quarts. I usually just fill up till you the oil is about a half inch or so below the fill plug. tjkj2002 knows the amount.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #7 of 11 Old 09-03-2010, 08:49 PM Thread Starter
VMF
2008 KK Liberty
i see, well i hope he replies soon, this mobil 1 oil is rather expensive, not sure why corporate went with it, i liek the one dana uses much more we put it in the rubi all the time. and i find it weird that the manual does not state the amount of oil required...
2004 UCF31. Black
VMF is offline
post #8 of 11 Old 09-03-2010, 08:52 PM
tjkj2002
2002 KJ Liberty
Between the 2 axles you will only need 4qts and should have a 1/4qt left over.
Synthetic gear oil needs to be changed every 12k-15k,dino gear oil can go longer(I still recommend 12k-15k drains still anyways).
tjkj2002 is offline
post #9 of 11 Old 09-03-2010, 11:13 PM Thread Starter
VMF
2008 KK Liberty
Wow that's quite an often change so u use same synth oil for dana as well? We only put recommended oil into d44s ok the jk, why do u think this oil with diff properties is better?
VMF is offline
post #10 of 11 Old 09-04-2010, 05:37 AM
tjkj2002
2002 KJ Liberty
I can only run dino gear oil(85w-140) in my diff,more so for the rear to keep the warranty as synthetic gear oil will kill my rear axle fast.
Diffs are the only item in your vehicle where synthetic oil is not best.
tjkj2002 is offline
post #11 of 11 Old 12-15-2011, 08:28 PM
bagwell
2011 KK Liberty
hummm, curious....why is this??
bagwell is offline
08 KK Automatic Transmission fluid & Filter change without a dipstick mjcougler KK Liberty Forum 18 10-09-2012 11:00 AM
Rear axle info? gunselman KK Liberty Forum 1 09-02-2010 10:40 AM
Change US to Metric 2009 3,7l Sport suzuki_gixxer KK Liberty Forum 1 07-06-2010 01:36 PM
