anyone install an aftermarket remote starter on KK? - JeepForum.com
post #1 of 3 Old 03-25-2010, 10:03 AM Thread Starter
gb0413
I am looking into getting a remote starter installed (aftermarket) on my '10KK. We have extremely cold winters where i'm from so i thought this might be a nice advantage since the dealer wasn't offering any models that had this feature. Anyone else have this? opinions?
gb0413 is offline
post #2 of 3 Old 03-25-2010, 11:12 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ive got the Viper Alarm and Remote Start with 1 Mile Range and its 2 Way. Been installed for 2 Years Now.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 3 Old 03-26-2010, 01:11 PM
08KKJeepGrn
2015 JK Wrangler
Yup!. I got one installed.. Works pissssa. Range is about 1000ft + and on this remote starter the guy didn't have to work with a 2nd key from Jeep. here's a picture of the remote .... it's about 1 inch in length.. has been programmed to start the vehicle when it's either locked or unlocked. (most of time the Jeep is locked) and you can use your key fob to hit the unlock button while the remote is running.
info... Prestige(by Audiovox) APS901N Long Range Remote Starter Model # APS901N
Start your car up to 1200 feet away with this Prestige remote starter
Auto starter allows you to select run times at 20, 15, 10 or 5 minutes
Remote starter has LED status indicator
Ignition 3, shock by pass, GM VAT output relay required
Tach signal learning circuit
Two positive and two negative safety shutdown circuits
Alarm by pass output
Accessory outputs, pulse before and after start, during crank and after shut down
Selectable steady or flashing parking lights for run indication
Optional door unlock feature for vehicles equipped with power doors
Telematics port, telematics upgrade ready
DBI port plug in flash logic by pass capable
08 Liberty Limited Jeep® Green
'15 Jeep Wrangler Unlimited Silver
08KKJeepGrn is offline
Rocky roof rails install?? stubble88 KK Liberty Forum 20 04-26-2015 07:00 PM
how to install back up cam?? sofixj KK Liberty Forum 9 01-04-2014 07:56 PM
08 Liberty Sirius Install Kit dnocito KK Liberty Forum 2 10-30-2010 06:14 PM
KK Satellite Antenna Install sbougon KK Liberty Forum 2 10-30-2010 01:45 PM
KK remote key lock metallicjeep KK Liberty Forum 7 03-24-2010 06:09 PM
