Any KK Owner w/ K&N CAI? - Page 4 - JeepForum.com
post #46 of 59 Old 08-30-2012, 10:19 AM
tommudd
2004 KJ Liberty
Why spend the money on something that gains you nothing but a little sound?
tried all of the "crap" that says it will give you more power etc
The stock box does what its suppose to and works , period
I'll save my money for things that actually make a vehicle better
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #47 of 59 Old 08-30-2012, 01:30 PM
huntb
2008 KK Liberty
The K&N CAI with the Hypertech program gave me at least 2mpg more and more power. Probably more the Hypertech but I like to think the K&N helps her breath a little better and helps with throttle response. But what do I know, I'm an electrical engineer not an automotive engineer
huntb is offline
post #48 of 59 Old 08-30-2012, 01:49 PM
tommudd
2004 KJ Liberty
But you can read right
Read up on how much dirt and crap the K&Ns let into your intake for one
Bad choice, stock paper filter does a better job and just the same overall mileage
Spend your money on true upgrades, not something that harms the engine in the long run.
MUDD'S MOTORSPORTS
tommudd is offline
post #49 of 59 Old 08-30-2012, 02:03 PM
tjkj2002
2002 KJ Liberty
Your PCM can correct for up to a 80% clogged air filter with zero loss of mpg's so it's impossible for a "freeier flowing" air filter without internal engine mods and programming to take advantage of those engine mods to actually warrant more air flow then what the OE box provides.Besides the OE box is a true cold air intake while the k&n setup is a hot air intake system.
Your throttle response thoery is false also since the PCM also controls that,you have no throttle cable.All you achieved is more noise and dirtier engine oil.
tjkj2002 is offline
post #50 of 59 Old 08-30-2012, 09:40 PM
huntb
2008 KK Liberty
See that's why I come to this site. You guys are all way smarter than me. I guess all those horse power and torque graphs K&N puts on their site is just all false advertising. Maybe I'll start a multi million dollar company selling dirt and tell everyone it will make you jump higher
huntb is offline
post #51 of 59 Old 08-30-2012, 10:55 PM
Poncherello
2010 KK Liberty
I think if you wanted to do an airfilter modification, maybe a snorkel filter would be good, if you plan on doing some serious wheel'n. On the other hand, back in the day my buddy had a 74' GTO with a shaker hood scoop. It made the car look awesome and also helped it performed better when it opened up. The car had a 350 with a 4 barrel carb. Unfortunately he didn't own it long enough and ended up totaling it
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #52 of 59 Old 08-31-2012, 12:04 AM
tjkj2002
2002 KJ Liberty
You may see a very small increase at 1st but after a few driving cycles the PCM will "relearn" and set everything back to what it has been programmed to so anything you may have gained will be lost in a few days.Even adding a true cold air intake,or I should say better one then the OE setup,also will never gain you anything as again the PCM will learn around it.Via the MAP sensor and AIT sensor the PCM will adjust accordinly to it's pre-set fuel maps.That is where they get there dyno graphs from,they just slap the kit on a dyno it but if they did a before and after with about 2 weeks in between you would see no increase.
Dealing with carbed engines is a whole nother story where spacers and such actually do work but do nothing on a multi-port FI engine.
tjkj2002 is offline
post #53 of 59 Old 08-31-2012, 10:46 AM
huntb
2008 KK Liberty
This isn't true with the Hypertech programmer. It completely remaps your PCM
huntb is offline
post #54 of 59 Old 08-31-2012, 11:19 AM
tjkj2002
2002 KJ Liberty
They don't come close to re-mapping the whole PCM,just some high rpm data is all.Anyways still pretty useless without internal engine modifications to actually see any real benifit from changing the programming.Without internal mods no amount of programming will see any meaningful gains since your still working with the same internal dynamics the stock programming is.
tjkj2002 is offline
post #55 of 59 Old 09-01-2012, 02:23 PM
SilenceOfDaPwnd
My K&N should be in on the 5th
I will install and update
SilenceOfDaPwnd is offline
post #56 of 59 Old 09-01-2012, 03:33 PM
tommudd
2004 KJ Liberty
Funny some of us have been playing/ working on these Libertys for 8-10 years but when someone asks for advice it means nothing
believe the hype K&N puts out if you will , its your dollars lost
MUDD'S MOTORSPORTS
tommudd is offline
post #57 of 59 Old 09-01-2012, 04:00 PM
SilenceOfDaPwnd
I accidentally thought this was jk
Lol
I'm a jk owner
*fail
post #58 of 59 Old 12-31-2012, 06:55 PM
27tubguy
2008 KK Liberty
snorkel for a KK?
Anyone got a line on a KK snorkel kit.
Richie from Boston
27tubguy is offline
post #59 of 59 Old 06-12-2015, 12:57 PM
libertyordeath8
2003 KJ Liberty
Just wanted to say thanks to all who contributed to this ancient post. Very informative and excellent points all around. If mr. Guinney pig is still around, (sorry i cant lookup ur name on my mobile device right now, silv-something? Sorry) how is that air intake working out? PCM ever recalibrate itself?
libertyordeath8 is offline
