Amp and Sub to 09 Liberty stock radio? - JeepForum.com
post #1 of 8 Old 06-19-2011, 10:57 AM Thread Starter
Gustaj85
2009 KK Liberty
I have an 09 Liberty with the stock single disc w/sirius sat radio. I also have a single 10" sub and a 500w amp (didn't want much, just a lil more bass). How do I connect this to the stock system in my Liberty, I really don't want to change the head unit. Is there an adapter for the connector behind the radio, or what do I do?
Gustaj85 is offline
post #2 of 8 Old 06-19-2011, 06:53 PM
Jeepin11
2011 KK Liberty
I was wondering the same thing.
2011 KK- 265/75-16 Wrangler Authorities on 16x8 Racelin Assault wheels
Jeepin11 is offline
post #3 of 8 Old 06-20-2011, 07:28 PM
SuperRliBerty
2008 KK Liberty
You will need a 4 channel adapter to convert the speaker level audio to lo level audio. I installed this one.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #4 of 8 Old 06-20-2011, 07:40 PM
SuperRliBerty
2008 KK Liberty
This is the wiring diagram. All KK's have the white connector that contains the speaker level out.
http://www.jeepforum.com/forum/f292/...chart-1127933/
2008 Sport Liberty
post #5 of 8 Old 06-20-2011, 07:54 PM
SuperRliBerty
2008 KK Liberty
you can get the plug-n-play harness from coastaltech. this is better than the adapter. check out the lockpic at their site: http://www.coastaletech.com/LIBERTY_INSTALL.htm
2008 Sport Liberty
post #6 of 8 Old 12-24-2011, 03:19 PM
velocityss1985
Please explain how that plug and play harness works? Do you use the audio outputs? Signal?
velocityss1985 is offline
post #7 of 8 Old 12-24-2011, 04:04 PM
bagwell
2011 KK Liberty
plug and play means it plugs directly into the head unit and voila, you have your RCA outs....BUT I don't think this is the correct harness.
bagwell is offline
post #8 of 8 Old 12-24-2011, 04:21 PM
velocityss1985
I have that harness installed above along with the lockpic. I just went out and looked at it. It says video/audio output on the one set of RCAs. I measured the mV across the + and - it doesn't seem like a strong enough signal. My amp wants at least 200mV but I was measuring in the 100 range. What would be the correct harness? There is an open ended white plug that I believe has the speaker leads. I was wondering if I should use the speaker leads and a line level converter or if I should use those RCAs like above and go directly to the amp with them.
What Liberty to get? wwessels KK Liberty Forum 10 05-01-2011 08:40 PM
Getting rid of my liberty... JFD140 KK Liberty Forum 2 12-09-2010 05:06 AM
5W-40 on Liberty KK 3.7 nkanakakis KK Liberty Forum 6 11-02-2010 02:35 PM
Should I get a Liberty? kinsale KK Liberty Forum 13 10-31-2010 06:49 AM
Getting Liberty on monday! Radio question... Tanya KK Liberty Forum 6 10-08-2010 08:48 PM
