All 4 power windows won't go up =( - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > All 4 power windows won't go up =(
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!
Unread 05-26-2010, 11:53 AM   #1
MikePM
Figured it out. Wasn't a fuse, it was the master control module on the driver's side door. Popped it out, saw the connections had come out, probably from the previous owner slamming the sh*t out of the door. Easy fix, now it's good to go.
MikePM is offline   Reply With Quote Quick reply to this message
Unread 05-26-2010, 11:54 AM   #2
MikePM
Other than paying some else to look at it =)
Unread 05-26-2010, 12:35 PM   #3
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ya def sounds like a fuse, i just dont know which one controls those
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline   Reply With Quote Quick reply to this message
Unread 05-26-2010, 12:58 PM   #4
MikePM
Yea that's what I really thought it was, the fuse. Anyone have a link to a fuse diagram? Still, I checked them all with my fuse detector and they all got the green light so it might be another issue. I really don't want to pay someone else to fix some small electrical problem that I can probably fix myself.
Unread 05-26-2010, 10:33 PM   #5
richd
2008 KK Liberty
Isnt your 08 still covered under warranty?The fuse for driver window switch is cavity m26,the outside mirrors are on the same circuit.do your mirrors work?It also could be a module problem.
richd is offline   Reply With Quote Quick reply to this message
Unread 05-27-2010, 07:50 AM   #6
z06boy
2010 KK Liberty
Wow that's terrible and yes unacceptable. I wouldn't be happy. I only have about 5k miles on my 2010 Liberty and so far so good. I've had just a few 'issues' but they've been addressed.
z06boy is offline   Reply With Quote Quick reply to this message
Unread 05-27-2010, 04:10 PM   #7
daggo66
2009 JK Wrangler
Do they work from the driver's door? If so you may have pushed the button that inactivates the individual doors.
Tom
daggo66 is offline   Reply With Quote Quick reply to this message
Unread 06-12-2010, 05:24 PM   #8
Chilly
Just pull all the fuses one at a time and look at each one.
05 Unlimited 3" lift, 33" MT MTZ so far
Chilly is offline   Reply With Quote Quick reply to this message
