Adding Spacers to a Jeep Liberty Jet - JeepForum.com
 1Likes
  • 1 Post By lfhoward
post #1 of 6 Old 08-28-2017, 11:01 PM Thread Starter
Shodan85
2011 KK Liberty
I want to know how possible it is to add wheel spacers with my stock suspension on my 2011 Jeep Liberty Jet. Current tires are 245/50r20.
Shodan85 is offline
post #2 of 6 Old 08-30-2017, 11:45 AM
tommudd
2004 KJ Liberty
So you are wanting a lot of rubbing when turning around/ into any driveway etc ? If so go ahead.
But seriously adding wheel spacers unlifted will do noting but cause extra rubbing due to the arc the tires turn in
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #3 of 6 Old 08-31-2017, 11:36 AM Thread Starter
Shodan85
2011 KK Liberty
Good info, thank you! What would be the minimal ideal lift height to ensure the rubbing doesnt occur?
Shodan85 is offline
post #4 of 6 Old 08-31-2017, 03:12 PM
lfhoward
2008 KK Liberty
I would think at least 2.5 inches of lift, depending on how thick your wheel spacers are. If contemplating this, go with a full spring lift from OME (their 1.5" kit actually nets your Jeep 2.5") or JBA. Spacer lifts are not a long term solution as they damage your suspension components over time and ride poorly compared to a full spring lift.
tommudd likes this.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #5 of 6 Old 09-23-2017, 11:46 PM
n32rra
2011 KK Liberty
I too have a 2011 Liberty Jet with those 20" rims. I installed a 1" hubcentric wheel spacer on mine with stock suspension. I did not notice any rubbing. Anything more than that will cause rubbing. I just recently replaced my rim and that moved the wheels out about 1 1/3 inch. There is a very slight rub in the rear panel of the front tire. The good thing is that the panel is soft plastic (flexes) so it has not caused any real issues.
n32rra is offline
post #6 of 6 Old 09-24-2017, 01:11 AM
bjase25
I recently installed Rough Country 2.5 spacers on my 2012 liberty and was able to move up 2 sizes in tires. Stock size was 235s and I now have 265 70 R17 no rubbing and no problems.
bjase25 is offline
