Adding Fog Lights - JeepForum.com
post #1 of 35 Old 11-29-2010, 08:03 PM Thread Starter
cmlohff
2008 KK Liberty
Adding Fog Lights
I own a 2008 Jeep Liberty Sport 4x4. I haven't done any modifications on it yet but plan to. I was wondering if it was possible to add fog lights, as mine does not have them. Would this require buying entirely new head light units for each side (too expensive) or is it possible to remove the caps covering the holes where the fog lamps should be and install them on my own? If it is possible, then how hard would it be to install them?
cmlohff is offline
post #2 of 35 Old 11-30-2010, 05:17 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Nope, need to replace the housing. I think they go for like 250ish for the whole kit. And Welcome to the forum
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 35 Old 11-30-2010, 02:00 PM Thread Starter
cmlohff
2008 KK Liberty
Thanks for the welcome. I have been looking around and it seems that the only parts I can find online are around $200 for each side. Are there cheaper after market parts somewhere?
cmlohff is offline
post #4 of 35 Old 11-30-2010, 02:35 PM
SCT100
2010 KK Liberty
You can always pick up aftermarket fog or driving lights at any auto parts store. You have to know a little wiring, and you have to mount them somewhere on the fron of the Lib. They usually look bad, but I have seen a few that look good.
SCT100 is offline
post #5 of 35 Old 11-30-2010, 02:43 PM Thread Starter
cmlohff
2008 KK Liberty
Would it even be wort asking the dealership down the road what they would charge?
cmlohff is offline
post #6 of 35 Old 11-30-2010, 02:53 PM
SCT100
2010 KK Liberty
The PC answer is "it never hurts to ask."
However, it's a dealer, so don't be shocked when they quote you a thousand, or dare I say... One hundred billion dollars (Dr. Evil reference ), for the parts and the install.
SCT100 is offline
post #7 of 35 Old 11-30-2010, 05:26 PM
SuperRliBerty
2008 KK Liberty
I got a pair similar to these below, I installed it in the lower front. I wired a relay and a switch where it is not powered when the keys are in the on position, on when the engine is running.
Dodge-Charger-Pre-Assembled-Halo-Headlights-Conversion-Lighting-Fog-Lights-118654-ORACLE-471.jpg
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #8 of 35 Old 12-01-2010, 12:18 AM
VMF
2008 KK Liberty
post pix of them installed pls. and dont forget to turn them on
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #9 of 35 Old 12-02-2010, 05:10 PM
SuperRliBerty
2008 KK Liberty
VMF, my camera took ship the bed and this is the only pic I have right now to show the fog lights I installed...... they cost $29.95 at discount auto store. they light up the street about 50ft ahead...
2008 Sport Liberty
post #10 of 35 Old 12-02-2010, 05:23 PM
tjkj2002
2002 KJ Liberty
100% OEM parts,all parts included,and factory looks.
Fog Light Kit(2008-2009) Factory Jeep Parts, Accessories, Cherokee, Liberty Wrangler
tjkj2002 is offline
post #11 of 35 Old 12-02-2010, 05:49 PM Thread Starter
cmlohff
2008 KK Liberty
I like that look. Very minimal and sounds like they work great!
Originally Posted by tjkj2002 View Post
Thanks! So I think I will look into this one further.
cmlohff is offline
post #12 of 35 Old 01-22-2011, 07:41 PM
jeepernj
2008 KK Liberty
Hey SuperRliberty, that looks great! Would you be able to post pics of how you mounted the lights or at least explain how you did it? I have been looking for a way to mount my fogs for a while? Thanks
08 KK 6-Speed Manual (the only way to go)
jeepernj is offline
post #13 of 35 Old 02-19-2011, 02:17 PM Thread Starter
cmlohff
2008 KK Liberty
Sorry to bring this thread back up, but I have finally found some time to look into installing fog lights. Would you be willing to explain how to install fog lights the way you did SuperRliberty? I am wondering if it is possible to make it do I can turn them on and off whenever I want and install the switch in the blank buttons on the bottom of the center console?
cmlohff is offline
post #14 of 35 Old 02-19-2011, 07:04 PM
SuperRliBerty
2008 KK Liberty
Cmloff, I purchased those foglights from Advance auto. $29.99. It came with a pair of fog lights, lighted switch, fuse holder and relay. The wiring instructions are included.
I wired the relay power to the accessory fuse box. So I can manually turn on the fog lights when the key are in the ignition in the "ON" position or engine running.
The switch is lighted red for on, green for off.
2008 Sport Liberty
post #15 of 35 Old 02-20-2011, 06:55 AM Thread Starter
cmlohff
2008 KK Liberty
Thanks!
cmlohff is offline
Driving lights cnypt KK Liberty Forum 3 12-23-2015 10:28 PM
Mopar/Factor Fog Lights ericw08 KK Liberty Forum 7 09-15-2010 11:33 AM
ESP/BAS lights lukes KK Liberty Forum 0 03-31-2010 03:26 PM
LED lights for reverse lights Wnahikian KK Liberty Forum 0 02-17-2010 08:48 AM
