Accessory Switches not working - JeepForum.com
post #1 of 4 Old 11-01-2010, 09:15 PM Thread Starter
dpa43
2008 KK Liberty
I picked up my 08 Liberty about two weeks ago and noticed it has the switches for the power inverter and the ESP. I have noticed that none of the switches below the HVAC controls work. The only one that does is for the hazards. Has anyone else had this problem or know of the fix for this problem.
dpa43 is offline
post #2 of 4 Old 11-02-2010, 01:29 PM
richd
2008 KK Liberty
Check for a bad connection behind the panel.I remember hearing about this a couple times.
richd is offline
post #3 of 4 Old 11-02-2010, 02:21 PM
SuperRliBerty
2008 KK Liberty
Check the fuses and relays in the engine compartment. There is a fuse and a relay dedicated to the inverter pwr sytem.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #4 of 4 Old 11-13-2010, 05:42 PM
wevee
Had the exact same problem on my 08 Liberty. There is a circuit board behind the buttons. There is a 4 pin connector coming out the back side. The 4 pins were not soldered into board, they were just pushed through a tight opening with no solder. I don't know if this is by design or somebody forgot to do it but I soldered mine and everything worked again. The face plate that runs up to the storage tray has to be removed to gain access to the area where the circuit board is located.
wevee is offline
a/c stoped working capsfloyd KK Liberty Forum 8 09-19-2011 01:16 PM
