7500 miles and suspension problems. - JeepForum.com
post #1 of 13 Old 09-09-2012, 03:23 PM Thread Starter
Arctic_Libby
2012 KK Liberty
Bought my 2012 Liberty Arctic right when winter ended. I've gone off roading twice on actual trails. Other than that whatever I can do in the back yard. My only problem is I drove over a speed bump today and the suspension sounded like a cheap motel mattress. How is it possible that the suspension sounds like that already? I didn't push it real hard on the trails, didn't fly over the trails, and basically crawled through puddles.
Also, how picky will the dealership be if I bring it in and try to have the warranty cover this?
Any help is appreciated.
Arctic_Libby is offline
post #2 of 13 Old 09-10-2012, 09:32 AM
Kylv
2011 KK Liberty
As long as you didn't run into something and mangle the suspension components, it's covered under warranty. The Jeep is advertised as an off-road vehicle, that does not void your warranty.
Kylv is offline
post #3 of 13 Old 09-15-2012, 04:19 AM
harp666
2012 KK Liberty
Look at your spare tire,mine was making noise as well and tire was loose,tight it up and all is fine now.
harp666 is offline
post #4 of 13 Old 09-15-2012, 04:24 AM
fosterjd79
Off road vehicles make noise. The components get covered in dirt, dust, mud, etc. Give it a good bath, including an undercarriage wash. I'm sure it's fine. Hey, it is a Jeep after all, creaks and leaks are its way of reminding us of that.
fosterjd79 is offline
post #5 of 13 Old 09-15-2012, 06:34 AM
tjkj2002
2002 KJ Liberty
Yep if you play in the mud the 1st thing should be to clean the undercarriage very well with high pressure water.Mud destroys seals,bushings,u-joints,and promotes faster corrosion.Don't wait for it to rain or 3-4 weeks later since "it looks cool to be covered in mud".
tjkj2002 is offline
post #6 of 13 Old 09-15-2012, 09:18 PM
streetglideok
2005 KJ Liberty
Sway bar bushings would be suspect. Offroading stresses them on any vehicle, if you do not use disconnects. Get some silicone spray, and lube them, and see if it goes away.
streetglideok is offline
post #7 of 13 Old 09-16-2012, 04:12 PM Thread Starter
Arctic_Libby
2012 KK Liberty
Alright, appreciate all the help guys! Thanks!
post #8 of 13 Old 09-16-2012, 06:50 PM
tjkj2002
2002 KJ Liberty
Yeah clean your Jeep,it's not a warranty issue.
tjkj2002 is offline
post #9 of 13 Old 09-16-2012, 08:39 PM Thread Starter
Arctic_Libby
2012 KK Liberty
The only problem with this is that I went offroading on Saturday and it started making noise from the wheel well. So instead of me just power washing it, I took it to an actual car wash and got the under body wash. Noise was still there in the wheel well. Pulled off the wheel and found a tiny stick stuck in the brake rubbing against the disk. Took that out and noise went away. Later in the week when I would turn hard and have some speed (on regular roads) there was a sharp screeching noise. It comes and goes. Haven't gone offroading inbetween the wash and that next noise.
post #10 of 13 Old 09-16-2012, 08:48 PM
tjkj2002
2002 KJ Liberty
Those automatic car washes,the ones you drive through,are worthless for there undercarriage wash.May get 5% or less of anything actually clean.You need to spend a good 10-20mins with the self serve powerwasher and get in every nook and crany.Yes you will get wet.
The phrase "gotta pay to play" comes into effect.You took it offroad and any damage done offroad is not a warranty issue.Blah.blah,blah you see the adds with Jeeps offroad so they must not break offroad.Well it will break and if offroad it's not a warranty issue,just how it is.When you break it offroad you went passed the limits,which sadly these days in stock form is no more then soccer mom duty, and just a reason to upgrade.
tjkj2002 is offline
post #11 of 13 Old 09-16-2012, 09:34 PM Thread Starter
Arctic_Libby
2012 KK Liberty
So then let me ask...good suspension for a 2012 liberty? I've done some looking around and it seems the only one I can find is a Rock Krawler X Factor or something like that. 3.5" in the front and 2" spacers for the back.
post #12 of 13 Old 09-16-2012, 10:47 PM
tjkj2002
2002 KJ Liberty
Yeah RK sucks,likes to supply there kits with grade 2 hardware.
Now quality and great customer service don't come cheap,keep that in mind.The only place I'd be looking for your KK.
http://jeepinbyal.com/
tjkj2002 is offline
post #13 of 13 Old 09-17-2012, 07:49 AM Thread Starter
Arctic_Libby
2012 KK Liberty
Alright I will definitely check them out. Thank you
How many miles on your KK? 2011KK70AE KK Liberty Forum 188 05-26-2015 08:03 PM
miles until empty wrong36 KK Liberty Forum 23 08-23-2013 01:32 PM
Miles to empty?? JerseyFKY KK Liberty Forum 7 08-06-2012 06:46 AM
Miles with fuel light? JasonBanz KK Liberty Forum 7 06-11-2012 04:36 PM
TWO oil changes in 5,000 miles? bmwcali KK Liberty Forum 26 04-20-2010 05:23 PM
