4WDlow and boat ramps - JeepForum.com
post #1 of 11 Old 02-11-2013, 07:21 PM Thread Starter
HSOUSA
2012 KK Liberty
My lib has the command-trac ll 4x4 system. It has served me great so far and I didn't have any problems in the last big snow fall we had, even with the stock 20" rims and all season tires.
I am a die hard angler (it's a sickness, I swear) and I own a 14ft aluminum boat.. I have yet to tow it with the lib but I imagine it will do well.
My question is, lets say I was retrieving my boat from the water and I got stuck on slippery algae or the ramp was exceptionally steep and the wheels were to spin.. how would I engage 4WD low? To my understanding, the vehicle must be moving to engage 4WD low, right?
4WD hi isn't a option because of course, this is a part-time 4WD system. If I were to engage 4WD high and kept the steering wheel straight, could I still damage something?
Any input is appreciated..
HSOUSA is offline
post #2 of 11 Old 02-11-2013, 07:23 PM
KK4x4
2009 KK Liberty
Put it in neutral then 4low then drive and there ya go! Doesn't always have to be moving
KK4x4 is offline
post #3 of 11 Old 02-12-2013, 04:17 AM
rescue575
2011 KK Liberty
Plus correct me if I'm wrong, 4hi on command trac is full time isn't it?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #4 of 11 Old 02-12-2013, 05:31 AM
richier2345
2012 KK Liberty
Yes, 4hi on commandtrac is full time
richier2345 is offline
post #5 of 11 Old 02-12-2013, 07:39 AM Thread Starter
HSOUSA
2012 KK Liberty
Sorry, I meant 4WD lock.. I don't have 4wd hi
HSOUSA is offline
post #6 of 11 Old 02-12-2013, 07:43 AM
rescue575
2011 KK Liberty
Again I could be wrong but from my understanding the command trac is full time 4wd when engaged. It is the select trac that is part thin when enabled.
2011 Liberty Sport
post #7 of 11 Old 02-12-2013, 09:07 AM
jonrjen
2011 KK Liberty
I prefer to think of Select TracII as advanced computer controlled traction on demand rather than being part-time.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #8 of 11 Old 02-12-2013, 09:15 AM
rescue575
2011 KK Liberty
Lmao. Good stuff.
2011 Liberty Sport
post #9 of 11 Old 02-12-2013, 09:57 AM
tjkj2002
2002 KJ Liberty
Your not understanding "full time" and "part time".
The select trac II has a full time 4wd option since it has a center diff that allows for "full time" use on any surface as that center diff(in the t-case) will allow the front and rear driveshafts to spin at different speeds.
The command trac II is a part time 4wd system,meaning it can only be used "part time" since when in any 4wd selection the front and rear driveshafts are locked together and will turn the same speed no matter what.
Oh and 4hi and 4lock are the same thing.
tjkj2002 is offline
post #10 of 11 Old 02-12-2013, 10:03 AM
rescue575
2011 KK Liberty
Your right. I was interpreting the terminology incorrectly. That's what happens when I read these posts at 6AM. Lol. My bad!
2011 Liberty Sport
post #11 of 11 Old 02-12-2013, 11:01 AM
swamppro
2008 KK Liberty
Never needed 4x4 in mine yet. I don't wanna use mine in 4x4 at all on the cement. Towing is no problem with our lib. I tow this beast all over.
swamppro is offline
