4LO light flashing? - JeepForum.com
post #1 of 10 Old 02-08-2011, 01:59 PM Thread Starter
kcphilaflyer
kcphilaflyer's Avatar
4LO light flashing?
So a girl in my office has an 08 Liberty and asked me to help her figure out her 4WD, she has a switch with 3 settings - 2WD, 4WD Lock, 4LO
So took her out in the snow to show how all 3 settings work, differences, etc.
But when it's in 4LO, the light is flashing, and its easy to tell it ain't in 4LO.
Does the flashing light mean somethings busted? Not that she's every going to need 4LO anyway, Im just curious about it now.
2005 Red TJ
6 Cyl 4.0L Manual Transmission, D44 Rear, 3.73 Gearing
32x11.5x15 BFG MTs on 15x8 Ravines w/ Spidertrax 1.25" Wheel Spacers
2" RE BB, 1" PA BL, 1" MORE MML
AtoZ Rockers, Uniden/2ft Firestick(stolen), Nth Degree Oil Skid, JKS Discos
1986 Red CJ-7 Spring '89 - Spring '96, R.I.P.
Red Jeep Club Member #289
kcphilaflyer is offline
post #2 of 10 Old 02-08-2011, 02:30 PM
rah8907
2011 KK Liberty
I believe the flashing light (4LO) indicates that you have selected 4LO, but that 4LO is not yet available. To get into 4LO, stop the vehicle, shift into neutral, select 4LO, then put it back in drive (or reverse). At least that's the way it work on my 2011 automatic Liberty.
Hope this helps - Roger
rah8907 is offline
post #3 of 10 Old 02-08-2011, 02:38 PM Thread Starter
kcphilaflyer
guess i never tried putting it in neutral and then switching it, sounds reasonable, thanks!
2005 Red TJ
post #4 of 10 Old 02-08-2011, 03:21 PM
SCT100
2010 KK Liberty
4Lo is a true gear reduction...have her read her manual, otherwise she is going to do some serious damage to her drivetrain at some point. You have to put it in neutral in order for the transfer case to engage 4Lo. This is not necessary for 4Hi.
Ps. The flashing light means the shift did not occur.
SCT100 is offline
post #5 of 10 Old 02-08-2011, 04:53 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
You must be rolling under 5 MPH, put it into Neutral, then engage 4WD LO. Or turn the engine off, turn the key to the on position but dont start the engine, apply brake, put it in Neutral then engage 4WD LO
Some more info on a similar issue. http://www.jeepforum.com/forum/f292/...stuck-1159569/
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #6 of 10 Old 02-09-2011, 08:10 AM
SCT100
2010 KK Liberty
I have found that 4Lo is best engaged while stopped in neutral. I tried the rolling at 2-3 mph as the manual says and I always get a big clunk/bang when 4lo engages. I dont get the clunk/bang when stopped and in neutral. Not sure why that is, but I use the "stopped-in-neutral" method.
SCT100 is offline
post #7 of 10 Old 02-09-2011, 09:06 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Sometimes you can do it while stopped, but the reason they say to do it 2-3MPH is because when stopped the teeth on the gears may not be lined up, and rolling slowly will help the teeth line up to engage.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #8 of 10 Old 02-09-2011, 09:14 AM
Korruptor
I've only ever used the 4lo once myself, but I did the low speed flip as well(~5kph). There was a clunk/bang for me too when it engaged.
Next time I'll try it while stopped
"THIS is my BOOMSTICK! You can find it in Aisle 5 of the sporting goods department... Shop Smart, Shop S-Mart!"
Korruptor is offline
post #9 of 10 Old 02-09-2011, 05:45 PM
ringertv
2011 KK Liberty
the owners manual states that that bang is normal, and the prefered method they say to use is the rolling method
ringertv is offline
post #10 of 10 Old 02-10-2011, 09:55 AM
SCT100
2010 KK Liberty
Yup, but I just don't like it It just "feels" like I am damaging it.
SCT100 is offline
CAL flashing above compas direction JACKTV KK Liberty Forum 1 02-08-2011 04:16 PM
Air Bag light ChuckPink KK Liberty Forum 4 12-03-2010 04:54 PM
Fog Light Aim ackeiyword KK Liberty Forum 2 10-30-2010 10:05 AM
3rd Brake Light Cover 2ksportNY KK Liberty Forum 3 09-12-2010 02:11 PM
Air Bag light gman1322 KK Liberty Forum 3 04-27-2010 07:16 PM
