40k Maintenance + Other regular maintenance - JeepForum.com
post #1 of 51 Old 07-22-2014, 06:35 AM Thread Starter
dtbingle
2011 KK Liberty
Approaching 40k miles and wondering if there is any maintenance work recommended around this area (ie. diff fluids, power steering fluids, spark plugs, etc). Just replaced my spark plugs and engine air filter.
Do you strictly follow the owner's manual? Do additional maintenance? Less? What do you all do in regards to maintenance work?
dtbingle is offline
post #2 of 51 Old 07-24-2014, 05:24 AM
Gageraid
2008 KK Liberty
I've been following the service manual for the most part.
Been doing the front and rear differential at 20K intervals. I did the transfer case at 50K, and transmission fluid at 50K.
Replace PCV now if you haven't done that yet ($20).
Definitely replace the spark plugs with copper core spark plugs and gap them to the correct gas as the manual says.
Would also be a good time to clean your throttle body.
I also changed my power steering fluid around 50K miles.
All of this maintenance can be done by yourself except the transmission.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #3 of 51 Old 07-28-2014, 08:41 AM Thread Starter
dtbingle
2011 KK Liberty
How critical are these replacements? For example, the auto trans fluid doesn't say to change until 128k and just to inspect/change if being used to tow, taxi, etc. Same scenario for the axle/tv fluids in the manual. Not trying to say you're wrong or anything, I'm just curious if it really should be replaced this often or if it's more just preventative measures. I don't do any water fording/trail runs - only roads/highways.
dtbingle is offline
post #4 of 51 Old 07-28-2014, 02:41 PM
Gageraid
2008 KK Liberty
The most crucial one is the spark plugs.
Other ones are pretty important if you want your Jeep to last a long time these other things will always help.
Lots of different information going around about the transmission fluid. I'd say that's the next important thing at 50K.
All maintenance items mentioned will only help your Jeep last longer. They are cheap and easy to do yourself with very basic tools and pretty much just the cost of oil.
OME lift
Gageraid is offline
post #5 of 51 Old 07-29-2014, 07:18 AM Thread Starter
dtbingle
2011 KK Liberty
How much does transfer case and diff fluid usually cost? Also, where did you find replacement pcv valve? Looking on autozones site, it doesn't show any that fit.
dtbingle is offline
post #6 of 51 Old 07-29-2014, 08:06 PM
Gageraid
2008 KK Liberty
Transfer case fluid is ATF+4 which is about 5 bucks a quart. The differential oil (gear oil) varies in price where you get it. About 10 bucks each. The front diff is easy, drain and replace, the transfer case is easy, drain and replace, the rear diff is the "hard" one that anyone can do.
Excellent way to save money.
EDIT-Got the PCV from the dealership for $20.
OME lift
Gageraid is offline
post #7 of 51 Old 07-30-2014, 07:13 PM Thread Starter
dtbingle
2011 KK Liberty
Great, I'll pick up some stuff and hopefully get to it this weekend. What do you do with the old fluids/oil? I'm guessing just drain into an oil pan, but then where do you dispose of it?
dtbingle is offline
post #8 of 51 Old 07-30-2014, 08:16 PM
RENE65
2008 KK Liberty
I would suggest that any fluids that REQUIRE replacement in your maintenance book should be done by your dealer to maintain proof of maintenance in case of breakdown later on.You can replace yourself anything that is not recommended NOW or that does affect powertrain warranty ex: air filter,spark plugs etc.
MY 2 cents worth
RENE65 is offline
post #9 of 51 Old 07-31-2014, 06:06 AM
Gageraid
2008 KK Liberty
There's a Napa up the road from me that takes it free of charge. I just call ahead each time so they know I'm on my way.
Gear oil smells REALLY bad. Your significant other and people in your family will tell you that you smell bad if you spill any.
OME lift
Gageraid is offline
post #10 of 51 Old 07-31-2014, 06:18 AM Thread Starter
dtbingle
2011 KK Liberty
MY 2 cents worth
Well, the manual only says only says inspect gear oil and replace if necessary. Same thing with transfer case fluid. Trans fluid is not until 120k. For all of the fluids, it says "change if used for police, taxi, etc" in the earlier life of the vehicle. PCV valve is like 88k miles and also says inspect and replace as necessary. So from what you said, there's no problem with doing these things (except the trans fluid, which the dealer has to do). On another note, what basic maintenance tasks fall under the category that could affect powertrain warranty?
dtbingle is offline
post #11 of 51 Old 07-31-2014, 06:22 AM
Gageraid
2008 KK Liberty
All of the maintenance on the KK is simple.
I can't think of any other maintenance items. Check your cabin air filter if yours is equipped.
You can check hub bearings and your cv axle boots for any rips or leaks. Also clean your throttle body.
OME lift
Gageraid is offline
post #12 of 51 Old 07-31-2014, 06:29 AM
RENE65
2008 KK Liberty
Engine oïl changes done regularly at the proper intervals is the most crucial maintenance to do. Make sure you have it documented.
RENE65 is offline
post #13 of 51 Old 07-31-2014, 07:22 AM Thread Starter
dtbingle
2011 KK Liberty
Been done every 3-3.5k miles. How do you document your maintenance log. Just write it down? If you have it done somewhere, you can keep the receipt as proof, but what do you do if you do maintenance yourself?
dtbingle is offline
post #14 of 51 Old 07-31-2014, 07:38 AM
RENE65
2008 KK Liberty
If you do the maintenance yourself keep a log of when and at what millage and keep the receipts for the purchase of oils and filters etc.
In simple words COVER YOUR ***
RENE65 is offline
post #15 of 51 Old 07-31-2014, 09:09 PM Thread Starter
dtbingle
2011 KK Liberty
Starting maintenance log now. Luckily most of my oil change and parts receipt are lying around somewhere.
dtbingle is offline
