4 wheel drive question - JeepForum.com
post #1 of 12 Old 03-18-2013, 08:04 PM Thread Starter
JeepJeepx
2011 KK Liberty
This is probably a stupid question..but how do I put my Liberty in 4 wheel drive?
Like do I have to be driving or stopped or what?
JeepJeepx is offline
post #2 of 12 Old 03-18-2013, 11:04 PM
kensil
2012 WK
There are two types of 4WD systems in the Liberty KK - each with a “normal” range (LOCK or AUTO) and a LOW range. In either case, shifts between 2WD and “normal” 4WD LOCK or AUTO can be done with the vehicle stopped or in motion. Shifts to the LOW range are more complicated and require the vehicle to be moving very slowly (3-5 mph) and the transmission to be placed in neutral before the shift. There are important differences between the two types of 4WD systems (Command-Trac II and Selec-Trac II). Command-Trac locks the drive system, which causes extra stress to the drive train when driving on dry pavement. Slec-Trac does not lock the drive system and can be used on any road conditions. Refer to the owner’s manual for more information.
kensil is online now
post #3 of 12 Old 03-19-2013, 01:15 AM
HMNG-Liberty
2012 KK Liberty
here's a video for select trac.
https://www.youtube.com/watch?v=g-tZtHVzJEI
HMNG-Liberty is offline
post #4 of 12 Old 03-19-2013, 07:57 PM
atwrk
2012 KK Liberty
LOL Glad you asked! I didn't dare I didn't really know what to do also. I always thought you had to be driving under 40 mph to put it in 4x4 mode high.
Good video, thanks!
I'm where?
atwrk is offline
post #5 of 12 Old 03-19-2013, 09:02 PM
Poncherello
2010 KK Liberty
Libertys didn't come with a paper manual but a DVD, in which there is an excellent explanation of the 4wd operation on there. I have the command track on my jeep. Only time I used my 4wd on the road was when there about 2 inches or more of snow on it uncleared or offroad on the beach.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #6 of 12 Old 03-19-2013, 09:47 PM
DeltaForceB85
2011 KK Liberty
Use is easy. For 4-Lock/Auto put the transmission in neutral while your driving and flip the switch. Then put it in gear and continue driving.
For 4-Low, slow down to under 4mph or stop, put the transmission in neutral, flip the switch, wait for all the lights to stop blinking (you should feel a very slight motion in the front end when it kicks in) then put it in gear and continue driving.
This is not entirely accurate. Neither command trac or select trac should be driven on pavement in 4-LOW. The difference is only in high (lock or auto).
Something else to note: when shifting to 4-LOW it works much better and makes much less noise to do it from a full stop. Also, more importantly when driving in 4-LOW in both systems the maximum speed you should drive is 25 MPH.
Where the two functions differ a little more drastically is in 4-Lock or 4-Auto. If you have command trac ii (4-lock) you should only use it in areas where you have low traction. If you have select trac ii (4-auto) you can use it anywhere.
-Josh
DeltaForceB85 is offline
post #7 of 12 Old 03-23-2013, 11:13 AM
mjcougler
2015 WK
I live in upstate NY. When I pull out onto my snow covered street and begin accelerating I simply slide the electronic switch into 4-wheel drive. Sometimes I think to let up on the gas, but often I don't.
Also, as long as there is snow or wet slush on the streets, I leave it in 4-wheel. Sometimes I drive to the right of the tire tracks where there is slightly more snow or wet slush. Then, when the road is more damp than wet slush I side the switch back to 2-wheel drive. I also try to never make tight turns at corners when driving on wet slush.
Am I doing damage?
Mike Cougler
15 Jeep GCL; 11 Jeep CL; 67 Jeep M725 Ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A
mjcougler is offline
post #8 of 12 Old 03-23-2013, 01:33 PM
lfhoward
2008 KK Liberty
I think you are fine. Your decision making process is the same procedure I use when I drive in slushy wintery mess. If the roads are just plain wet, I am in 2WD. And you only need to be in neutral when switching to 4-LOW.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #9 of 12 Old 03-23-2013, 03:34 PM
DeltaForceB85
2011 KK Liberty
Post removed.
-Josh
post #10 of 12 Old 03-24-2013, 11:19 AM
MyJKU14
2014 JK Wrangler
Used my 4wd yesterday with about 4" snow on the roads. We got about 12" total and it handled great. The key is knowing what your system is and understanding the limitations of the vehicle.
MyJKU14 is offline
post #11 of 12 Old 03-24-2013, 08:09 PM
DeltaForceB85
2011 KK Liberty
What limitations? Mine can fly!
(Ok so I busted an ac condenser, rim, tire, shock, bump stop, corner panel, shifted the cradle back half an inch and knocked my skid plates loose... but I flew!)
-Josh
post #12 of 12 Old 03-24-2013, 09:13 PM
rescue575
2011 KK Liberty
Ha ha! Well said.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
