4.10 Differentials Gears - JeepForum.com
post #1 of 16 Old 03-05-2014, 03:29 PM Thread Starter
NAMoulton
2010 KK Liberty
I'm looking into swapping gears to a 4.10 and am having a hard time actually finding a previous forum about it. Where do I get front and rear, what brand should I get, and do I need to swap out the differential housing/carrier to fit the 4.10 in there (if so where do I get the new housing). If anyone can help it would be appreciated, between me and the off-road mechanic, we cannot find anything specific. Thank You!
NAMoulton is offline
post #2 of 16 Old 03-05-2014, 04:59 PM
brucecadieux
2011 KK Liberty
From another forum.
After a very difficult search that in the end turned out to be solved by going to the source I've gotten the part number for a Dana Spicer 4.10 ring and pinion for the KK Liberty. A few people told me that the JK gears are the ones to use and they're correct but while trying to purchase a set, every list I saw said 02-12 KJ Liberty and every salesman told me that the JK gears wouldn't fit. Anyway, I called spicer and the part number is in fact the same as a JK. For 4.10 gears the number is 2005027-5. I provided them with the numbers stamped on my axel and there ya go. I even double checked with another source who ran the numbers and came up with the same answer. Unfortunately, they're $370.00 (oem) bummer.
Sorry the story was so long but I hope it helps.
http://www.lostjeeps.com/forum/phpBB...ic.php?t=45367
brucecadieux is offline
post #3 of 16 Old 03-05-2014, 05:01 PM
brucecadieux
2011 KK Liberty
post #4 of 16 Old 03-05-2014, 05:29 PM Thread Starter
NAMoulton
2010 KK Liberty
post #5 of 16 Old 03-05-2014, 11:10 PM
tjkj2002
2002 KJ Liberty
Originally Posted by NAMoulton View Post
None of those will work in your D30M front diff.You use JK D30 gear sets for the front of your KK.
tjkj2002 is offline
post #6 of 16 Old 03-06-2014, 07:00 AM Thread Starter
NAMoulton
2010 KK Liberty
Is this the 4.10 that is usable for the front diff? It doesn't say anything about it except that it's a 4.10.
post #7 of 16 Old 03-06-2014, 07:40 AM
huntb
2008 KK Liberty
If you read his post he says which one is for the front and which is for the rear before he posts the links.
huntb is offline
post #8 of 16 Old 03-06-2014, 10:20 AM Thread Starter
NAMoulton
2010 KK Liberty
I did see what he said, but the link doesn't say anything about whether or not that 4.10 is the one that would fit the D30.
post #9 of 16 Old 03-06-2014, 11:19 AM
huntb
2008 KK Liberty
disregard
huntb is offline
post #10 of 16 Old 03-06-2014, 11:26 AM
Bmxer524
2011 KK Liberty
It says "Ring and Pinion 4.10 Gear Kit, Ratio 4.10 2002-2005 Jeep Liberty KJ aluminum housing". You know if it fits the KJ it will fit the KK so we got that part. The next part says "aluminum housing". The D30 is an aluminum housing, don't ask me why, but this is how you know that it is for the front axle.
KJ and KK have different front diffs. If you're regearing the KK front end, you need JK front gears.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #11 of 16 Old 03-06-2014, 11:33 AM
tjkj2002
2002 KJ Liberty
X2.....
Guess nobody reads since I posted that in post #5.
tjkj2002 is offline
post #12 of 16 Old 03-06-2014, 07:37 PM Thread Starter
NAMoulton
2010 KK Liberty
That's what I've heard about the front diff, but which one? I guess there's reverse cut, short pinion, and normal and I have no idea which one I need.
post #13 of 16 Old 03-06-2014, 07:49 PM
tjkj2002
2002 KJ Liberty
JK front D30 gears are JK front D30 gears,no multiple choice to choose from.
tjkj2002 is offline
post #14 of 16 Old 03-06-2014, 08:59 PM Thread Starter
NAMoulton
2010 KK Liberty
post #15 of 16 Old 03-06-2014, 09:34 PM
tjkj2002
2002 KJ Liberty
The correct rears.............
http://jeepinbyal.com/jeep-liberty-2...nion-4-10.html
You need the newer metric bolt pattern which was changed from a SAE bolt pattern in '02(ring gear bolts).
tjkj2002 is offline
