265/65/17 On a Un-lifted 2009 Liberty KK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 265/65/17 On a Un-lifted 2009 Liberty KK
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSavvy/Currie Aluminum Control Arms
Unread 11-12-2014, 03:51 PM   #1
tsotop
Hey there, I'm new on the forum! I just bought at 2008 Liberty KK.
Well well, I'm planning to buy some new wheels since the current ones are too old.. so well, It has original stock wheel size (think is 245/70/17), so the deal is, i got a nice offer on some 265/65/17 AT wheels and I was wondering if that size fills my KK without rubbing.. (It has no lift)
Thanks everyone! Nice forum you have here!
tsotop is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 04:13 PM   #2
tommudd
2004 KJ Liberty
If you do in fact have the 245-70-17 on now with no rubbing then the new 265-65-17 should not rub since they are the same height basically.
BUT have to consider with full tread, tread pattern, style of the new tires they may or may not still rub. Some tires have more agressive tread pattern and will rub when turning etc, PLUS the fact with the age the KK will be sagging more
And calling your tires " wheels" will confuse a lot of people
Tires are the rubber bands that mount onto the wheels which are of various metals depending on brand and type
So you do not have 245-70-17 wheels
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 11-12-2014, 04:29 PM   #3
tsotop
Sorry well, I ment Tires,
My KK has 245/65/17 stocks, and I want replace them with 265/65/17 Pirelli Scorpion ATR without lifting or modification.. so thats kinda the whole thread..
Can this be possible?
Thanks in advance
Unread 11-13-2014, 10:03 PM   #4
JDePietro
2010 JK Wrangler
http://www.goodyearautoservice.com/c...eName=TireSize
Read all of that.
Basically the first letter(s) indicate what type of tire it is. The first series of numbers indicates how wide it is in milometers, the second series of numbers indicates how tall the tire is in relation to its width via percent.
Convert 65 to a decimal 65%= 65 / 100 = 0.65
0.65 x 265 = 172.25
172.25mm = 6.781 inch or round it to 6.8 inches wide.
265mm = 10.4 / 2 = 5.2 inches tall from top of rim to top of tread.
Hope that helps.
Man's got to know his limits.
JDePietro is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 02:46 AM   #5
Bmxer524
2011 KK Liberty
Read all of that.
0.65 x 265 = 172.25
Hope that helps.
Pretty sure you got this backwards. 265s are roughly 10.5" wide.
Anyways, 265/65-17s are roughly the same height as my 245/75-16, just a bit wider.
So to answer your question, no they will not fit. If you want to run them, you'll need about 2.5" of lift or so. The width might mean you'll have to pound the pinch weld, but that's no big deal.
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 10:48 AM   #6
huntb
2008 KK Liberty
Read all of that.
0.65 x 265 = 172.25
Hope that helps.
Wrong sir.
265/65R17
Width = 265mm = ~10.4"
265/65R17
Aspect ratio (sidewall height) = 65% of the width = 0.65*265 = 172.25mm = ~6.8" multiply by two for top and bottom = ~13.6"
265/65R17
Rim diameter in inches = 17"
Therefore total tire width (varies after being mounted to a rim depending on the width of the rim) = 10.4"
Total tire height = 13.6" + 17" = 30.6"
To answer OPs question - probably not. I'm running that same size with +15 backspacing and I get some rubbing at full lock in reverse and I have 3.5" of lift
huntb is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 11:16 AM   #7
JDePietro
2010 JK Wrangler
You're both right, I had my figures crossed.
