2011 Liberty - Slow trans fluid leak from gasket - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > 2011 Liberty - Slow trans fluid leak from gasket
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! April Instant Rebate: Up to $75 off Flowmaster Products!
Unread 04-17-2015, 09:48 AM   #1
dtbingle
2011 KK Liberty
After replacing trans fluid/filter awhile back, I ended up overtorque'ing one of the pan bolts and stripped the threads on the aluminum transmission housing. Due to this, it was slowly leaking ATF, so I had a shop fix it, which they said they put in a helicoil. The slow leak was still there. After this, I brought the jeep to the dealer, who straightened the pan out, put on a new gasket, refilled fluid, etc. A few weeks later when the weather got warmer, I noticed it was slightly wet with ATF around the gasket with a few drips on the pavement below. The vehicle is currently at the dealer again and they are going to take another look and possibly end up just putting on a new pan.
If this doesn't solve the slow leak, is there anything else I can try? Get rid of rubber gasket and use black RTV/gasket maker? Keep rubber gasket and also apply the RTV/gasket maker? Any other recommended products/solutions?
dtbingle is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 06:45 PM   #2
Oban
2012 KK Liberty
The KK comes with RTV on the transmission pan from the factory. Given the multiple bolt holes, the vibrations, exposure to various temperatures, and so on, I was never a fan of using an aftermarket gasket. If used properly, RTV is great (meaning you put RTV around the bolt holes, not just on one side, etc).
Also, I would install a new pan. They are cheap anyway. Straightening them out only goes so far. It will never be 100% true if it was bend out of shape.
2012 Jeep Liberty KK, 4x4, Mopar Hitch, Hood Lift Strut Mod, OME Lift, Bilstein Shocks
Oban is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 11:03 PM   #3
Ohiocowboy1277
I've tried straightening many trans pans and within a short amount of time the leak would return due to the deformed bolt holes. Even if you try hammering them out the metal is already stretched and slightly fatigued especially with the thinner cheaper steel on most newer ones so it won't take as much torque to deform it again even if properly tightened. Best bet would be a new pan as already stated
Ohiocowboy1277 is offline   Reply With Quote Quick reply to this message
Unread 04-18-2015, 12:37 PM   #4
Drednot
Drednot's Avatar
PML makes a heavy duty cast aluminum replacement. It has more capacity and fins to aid cooling, and a drain plug for easier maintenance. It also has a boss to drill and tap for a temperature probe.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 11:50 AM   #5
Ex-Calif
2012 KK Liberty
That's great info. If only for the drain plug!
2012 Liberty Sport
WWII - Horses vs. Jeeps - 'nuff said...
Ex-Calif is offline   Reply With Quote Quick reply to this message
