2011 "Gate Open" Switch Issue - JeepForum.com
post #1 of 5 Old 12-17-2012, 12:30 PM Thread Starter
dieseldogpi
Hey everyone. Yesterday my liberty started saying the gate was open out of no where. The dome lights would come on, etc. I figured its just a switch and I will look at it this weekend. Then last night, out of no where, my factory alarm started going off. I did do a little research and seen that this is a common issue, noting that the switch on the lift gate needs to be replaced. It has been raining pretty steadily, so I sure water got into the door and shorted the switch for it to only have acted up the past day or so. I am having trouble figuring out exactly what part I need to order to fix this. I think this is it:
http://www.moparpartsoverstock.com/p...5143017AA.html
But I am not sure. Looking for some verification on this. Thanks for the help guys.
91 YJ 4.0L under constant construction (sold)
99 WJ Laredo (with the in-laws)
Rescue Green '08 JK Unlimited (Gone)
2011 Charcoal Grey KK w/Sky Slider
dieseldogpi is offline
post #2 of 5 Old 12-19-2012, 10:00 AM
Eagle112199
2010 JK Wrangler
I had problems with wipers and headlights and it was my TIPM. Have a dealer check that too. There are many threads about problems with them on here. MOPAR's solution to a fuse box/computer thing and it is a known problem for some model years.
Jeep: It's a passion, not an obsession.
2010 JK Wrangler 2-Door
Soft Top
Eagle112199 is offline
post #3 of 5 Old 12-21-2012, 07:51 PM
kurnz
2008 KK Liberty
I have the same exact problem. And my jeep is taking water.
I removed the liftgate plastic trim and there is actually a bit of water into the gate.
The latch works great, but it keeps saying "gate" in the cluster. I can open it with the remote and the handle, no problem for this.
The glass won't open by the button or the remote, but I can open it manually from the glass latch. When I press on the remote, flashers light twice and nothing happens.
Do I have to replace the latch or a module or what?
By the way dieseldogpi, the part you refered to is for a KJ, not a KK
kurnz is offline
post #4 of 5 Old 12-31-2012, 01:23 AM
Ted15
2010 KK Liberty
You have the exact same problem I had. The root cause is the flipper glass seal. There is a TSB for this but they have to run your vin to see if it applies to your vehicle. Also, I'm not sure if it will be covered due to age. You'll need the gate latch and/or flipper glass latch as well as a window seal and an additional piece of seal material that looks like a rain gutter that goes across the top of the glass and diverts water to either side. This seems to have been a common problem up to 2010. Hopefully mopar covers your parts.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #5 of 5 Old 12-31-2012, 12:17 PM
marlon_jbt
2010 KK Liberty
A good dealer will apply the TSB anyway. And Ted's right, the entire tailgate latch has to be replaced. The water has gotten inside, which has led to corrosion.
Oh boy I'm so happy I don't have to deal with that water droplet residue anymore!!!
Red Jeep Club member # 264
marlon_jbt is offline
